order of attributes when writing a schema [message #52135] |
Thu, 02 September 2004 00:03 |
Originally posted by: gj.puredge.com
Is there a particular order of element attrinutes when writing out a schema.
For example, an element gets written as:
<xsd:element minOccurs="0" maxOccurs="1" name="NewField" type="xsd:string"/>
If I edit the xsd file and change the order, name first for example, it will
be written in that same order once I load it again and re-save.
Is there a way to control this?
Gary
Re: order of attributes when writing a schema [message #52163 is a reply to message #52135] |
Thu, 02 September 2004 10:08 |
Gary,
I believe that the underlying DOM typically sorts the attributes
alphabetically and serializes them that way. I've found it annoying
too, but I've seen no way around it. If anyone does, I'd be interested.
>Thanks
>Gary
Re: order of attributes when writing a schema [message #591277 is a reply to message #52135] |
Ed Merks Messages: 33236 Registered: July 2009 |
Gary,
>Thanks
>Gary
Ed Merks
FUDForum. Page generated in 0.02925 seconds
