JDialog Creation [message #52005] |
Mon, 26 July 2004 07:37 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: masterelettronik.yahoo.it
How ican make a JDialog with VE ? Can I make it changing the class
derived from JFrame to JDialog?
Thank you for the help!
(Excuse my poor English...)
Re: JDialog Creation [message #52030 is a reply to message #52005] |
Mon, 26 July 2004 13:08 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
In the New Visual Class Wizard, select Other as the visual class you'd
like to extend, then press the Browse... button next to the Superclass
field. Enter JDialog, then press Finish.
This should work ok. We've had a few problems recently with extending
JDialog. If the resulting code has problems, if you fix the code
yourself it should work. Otherwise, please try out the forthcoming M2
build.
- Jeff
Re: When is M2 sceduled? [message #52082 is a reply to message #52056] |
Mon, 26 July 2004 20:39 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Winni,
Any day now, just resolving a last few bugs before pushing it out the door.
- Jeff
Winni P. wrote:
> Hi Jeff,
> when is the release of M2 Sceduled?
> Thanks
> Winni
FUDForum. Page generated in 0.03520 seconds
