Home » Archived » Visual Editor (VE) » VE Plugin for Eclipse 3.0
VE Plugin for Eclipse 3.0 [message #51742] Sun, 25 July 2004 10:12 Go to next message
Originally posted by: rullger.ntlworld.com
Is there a version of the VE plug-in that will work with Eclipse 3.0?
I have installed the plug-in but when I try to enable it in Help >
Software Updates > Manage Configuration, I get the message:
Requested operation cannot be performed because it would invalidate the
current configuration. See details for more information.
Java EMF Model (0.5.0) requires feature "org.eclipse.jdt (2.1.1)", or
compatible.
The version of org.eclipse.jdt installed by default with Eclipse 3.0 is
v3.0.
Any help would be greatly appreciated.
Richard.
Re: VE Plugin for Eclipse 3.0 [message #51767 is a reply to message #51742] Sun, 25 July 2004 11:14 Go to previous messageGo to next message
Originally posted by: cyu021.spymac.com
These should help:
http://download.eclipse.org/tools/gef/downloads/drops/R-3.0- 200406251257/GEF-runtime-3.0.zip
http://download.eclipse.org/tools/emf/downloads/drops/2.0/R2 00406280827/emf-sdo-runtime-2.0.0.zip
http://download.eclipse.org/downloads/drops/R-3.0-2004062512 08/eclipse-SDK-3.0-win32.zip
http://download.eclipse.org/tools/ve/downloads/drops/S-S2004 0628-200406281448/VE-runtime-S20040628.zip
Enjoy,
James
> compatible.
> v3.0.
> Richard.
Re: VE Plugin for Eclipse 3.0 [message #51794 is a reply to message #51742] Sun, 25 July 2004 14:29 Go to previous messageGo to next message
Richard,
The latest stable build of VE works with Eclipse 3.0. Please see the
download page.
- Jeff
<Snip>
> Richard.
Re: VE Plugin for Eclipse 3.0 [message #51929 is a reply to message #51767] Sun, 25 July 2004 18:17 Go to previous message
Thanks James, I have downloaded the latest stable VE 1.0 build and this
has installed ok. All the other files were ok.
Thanks for your help.
Richard.
James Yu said the following on 25/07/2004 12:14:
> These should help:
> Enjoy,
> James
>> the current configuration. See details for more information.
>> or compatible.
>> is v3.0.
>> Regards,
>> Richard.
Re: VE Plugin for Eclipse 3.0 [message #595758 is a reply to message #51742] Sun, 25 July 2004 11:14 Go to previous message
James Yu is currently offline James YuFriend
These should help:
Enjoy,
James
> compatible.
> v3.0.
> Richard.
Re: VE Plugin for Eclipse 3.0 [message #595768 is a reply to message #51742] Sun, 25 July 2004 14:29 Go to previous message
Jeff Myers is currently offline Jeff MyersFriend
Richard,
download page.
- Jeff
<Snip>
> Richard.
Re: VE Plugin for Eclipse 3.0 [message #595823 is a reply to message #51767] Sun, 25 July 2004 18:17 Go to previous message
Richard.
> These should help:
> Enjoy,
> James
>> or compatible.
>> is v3.0.
>> Regards,
>> Richard.
Previous Topic:Where is VE?
Next Topic:Disable the synchronization between "design tab" and "the GUI instance" ?
Current Time: Fri Dec 27 02:56:42 GMT 2024
Powered by FUDForum. Page generated in 0.04850 seconds
