Eclipce Visual Editor [message #51520] |
Fri, 23 July 2004 19:17 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: kdford.us.ibm.com
Can someone give me step by step instructions on exactly how to install
the Visual Editor plugin to Eclipe 3.0?
Help would be greatly appreciated.
Ken Ford
Re: Eclipce Visual Editor [message #51688 is a reply to message #51520] |
Fri, 23 July 2004 20:52 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Ken,
1. Download the latest stable build of the Visual Editor
- Go the the VE download page and select the latest Stable build link.
- Download the required versions of EMF and GEF linked to on that
stable build page.
- Download the VE-runtime zip.
2. Unzip the plug-ins
- If you've renamed your Eclipse installation directory
* Create a temporary directory
* Unzip EMF, GEF and VE to this directory
* Move the plugins and features directories placed in this temp
directory into your Eclipse directory (ignore any overwrite warnings)
- Otherwise
* Unzip EMF, GEF and VE to the directory above your Eclipse
installation directory.
3. Run Eclipse
- If you've installed a previous build of VE, remove the
configuration directory in your Eclipse installation directory, or
launch Eclipse with the -clean parameter.
- Launch Eclipse.
4. Create a new Visual Class
- In a Java project, select New from the context menu and select
Visual Class.
The Visual Editor should launch successfully at this point.
- Jeff
> Ken Ford
Re: Eclipce Visual Editor [message #51691 is a reply to message #51520] |
Sat, 24 July 2004 13:39 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
> Ken Ford
you shoul download the files indicated (GEF,EMF,Visual editor Runtime)
the unzip them in directory that contain eclipse then when you start
eclipse it shoul work fine.
Re: Eclipce Visual Editor [message #595718 is a reply to message #51520] |
> Ken Ford
FUDForum. Page generated in 0.03676 seconds
