Home » Archived » Test and Performance Tools Platform (TPTP) » Problem with starting agent in linux
Problem with starting agent in linux [message #51480] Wed, 25 January 2006 06:53 Go to next message
Originally posted by: penbachi.rediff.com
hi all,
Iam using tptp in Mandrake linux.Iam using linuxia32 agent and iam
unable to start agent in linux meachine. I have ran SetConfig.sh and when
i try to start using RAStart.sh it failing to start.
The error message is like :
RAServer : error while loading libraries libstdc++-libc6.2-2.so.3: cannot
open shared object file: No such file or directory.
please help me,
Thanks in advace,
Bhaskar
Re: Problem with starting agent in linux [message #51508 is a reply to message #51480] Wed, 25 January 2006 16:07 Go to previous messageGo to next message
Originally posted by: Navid_Mehregani_nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 00589DEB85257101_=
Content-Type: text/plain; charset="US-ASCII"
Have you followed all the instructions in the getting_started guide.
Specifically:
* Add the <unzip directory>/lib directory to the system's LD_LIBRARY_PATH
environment variable.
* Add the <unzip directory>/bin directory to the system's PATH environment
variable.
Do a echo $LD_LIBRARY_PATH
echo $PATH to make sure.
Navid Mehregani
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Have you followed all the instructions
in the getting_started guide. &nbsp;Specifically:</font>
<br>
<br><font size=2 face="sans-serif">* Add the &lt;unzip directory&gt;/lib
directory to the system's LD_LIBRARY_PATH environment variable.</font>
<br><font size=2 face="sans-serif">* Add the &lt;unzip directory&gt;/bin
directory to the system's PATH environment variable.</font>
<br>
<br><font size=2 face="sans-serif">Do a echo $LD_LIBRARY_PATH</font>
<br><font size=2 face="sans-serif">echo $PATH to make sure.</font>
<br>
<br><font size=2 face="sans-serif">Navid Mehregani</font>
--=_alternative 00589DEB85257101_=--
Re: Problem with starting agent in linux [message #51532 is a reply to message #51480] Wed, 25 January 2006 16:42 Go to previous message
Originally posted by: claire.reynaud.trango-systems.com
I had same problem today.
I installed Mandrake package libstdc++2.10-2.96-0.83mdk.i586.rpm which
contains the missing library.
Claire
bhaskar a écrit :
> hi all,
> when i try to start using RAStart.sh it failing to start.
> cannot open shared object file: No such file or directory.
> please help me,
> Thanks in advace,
> Bhaskar
Previous Topic:How to Use TPTP
Next Topic:agent controler give an unexpected exception
Current Time: Fri Jan 03 00:02:43 GMT 2025
Powered by FUDForum. Page generated in 0.03781 seconds
