Help - Installation problems [message #51471] |
Tue, 02 November 2004 20:13 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: jeffmil.us.ibm.com
Folks, I've downloaded and unzipped both wtp-1.0M1.zip and
wtp-wst-1.0M1.zip and restarted Eclipse. I see nothing relate to Web
tools anywhere in the application. Is there something else I have to do
in the install?
Thanks alot,
<WS-Jeff>
jeffmil@us.ibm.com
Re: Help - Installation problems [message #51498 is a reply to message #51471] |
Tue, 02 November 2004 22:47 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: jmordax.terra.es
First of all, you just need wtp-1.0M1.zip (which includes
wtp-wst-1.0M1.zip).
Once you have installed that file, start Eclipse R3.0.1, go to: Help ->
Software Updates -> Manage Configuration... and make sure that the
feature is enabled.
Then, go to File -> New -> Other and make sure you have two folders
called: J2EE and Servers.
Please, notice that WTP M1 hasn't the functuonality needed to work on
J2EE projects.... so you won't see a JSP editor o a EJB wizard yet. But
things are moving.....
Chemi.
> do in the install?
> Thanks alot,
> <WS-Jeff>
> jeffmil@us.ibm.com
Re: Help - Installation problems [message #51546 is a reply to message #51498] |
Wed, 03 November 2004 13:08 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Chemi, that was it. I had looked there before and didn't see anything
related. But then I saw I had to show the disabled features and then I
could see the WTP stuff. And after enabling it I could see the
functionality in Eclipse. I have a few duplicate Preferences entries
around Servers and Web but I will clear that one up later. Thanks for
your help!
</WS-Jeff>
> wtp-wst-1.0M1.zip).
> feature is enabled.
> Chemi.
>> do in the install?
>> Thanks alot,
>> <WS-Jeff>
>> jeffmil@us.ibm.com
Re: Help - Installation problems [message #52244 is a reply to message #51471] |
Mon, 08 November 2004 14:17 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> in the install?
> Thanks alot,
> <WS-Jeff>
> jeffmil@us.ibm.com
Hi,i encounter this problem too.Anyone else can give me some advises?There
is nothing about install and usage in the webpage of WTP.
Hello,friend from world of eclipse.I am a new-bie in the world of java and
eclipse.I need your help to improve my ability and make the java world
better and stronger.
Re: Help - Installation problems [message #52297 is a reply to message #51546] |
Mon, 08 November 2004 14:49 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> your help!
> </WS-Jeff>
>> wtp-wst-1.0M1.zip).
>> feature is enabled.
>> Regards,
>> Chemi.
>>> do in the install?
>>> Thanks alot,
>>> <WS-Jeff>
>>> jeffmil@us.ibm.com
Very thanks your help,Chemi.I'm just forgotten that eclipse sometimes should
disable new features installed.
Thanks again.
Re: Help - Installation problems [message #53245 is a reply to message #51498] |
Sun, 14 November 2004 17:05 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: sam.psfdevrip-it.com
"Chemi" <jmordax@terra.es> wrote in message news:cm92qh$ad$1@eclipse.org...
> wtp-wst-1.0M1.zip).
> Software Updates -> Manage Configuration... and make sure that the feature
> is enabled.
> Please, notice that WTP M1 hasn't the functuonality needed to work on J2EE
> projects.... so you won't see a JSP editor o a EJB wizard yet. But things
> are moving.....
> Chemi.
Sorry for jumping in the middle of this thread.
I have wtp-1.0M1.zip. Do I unzip it into the root directory of my Eclipse
install? The rest of your instructions look pretty straightforward.
I use WebSphere at work and just downloaded and installed Eclipse
yesterday. All I can say so far is FANTASTIC! This will make testing code,
projects, etc. at home much more seamless!
SamMan
Rip it to reply
Re: Help - Installation problems [message #53302 is a reply to message #53245] |
Mon, 15 November 2004 09:16 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
The zip file should contain an eclipse dircetory with other two
directories: \plugins and \features; you should copy \plugins content in
top of your current \plugin dircetory and the same thing with \features one.
Hope this helps,
Chemi.
FUDForum. Page generated in 0.05869 seconds
