Home » Language IDEs » ServerTools (WTP) » A question about the example xsd editor
A question about the example xsd editor [message #51442] Tue, 02 November 2004 00:06 Go to next message
Originally posted by: dyx.gmx.net
Where do i find the code that implements the Attributes tab in the
tabbedPropertyView from the xsd editor model?
Re: A question about the example xsd editor`s property view´s atrributes tab [message #52436 is a reply to message #51442] Mon, 08 November 2004 17:41 Go to previous messageGo to next message
I.e. when you create a ComplexType and then go to the tab Attributes in
the Properties View. There`s a composite in which the attributes are
listed on the left and a table with the seleted attribute`s properties on
the right.
What is the name of the viewer/outline class that lists the attributes?
Where is this composite implemented?
Please anybody? Can you point me to the source code?
Re: A question about the example xsd editor`s property view?s atrributes tab [message #52505 is a reply to message #52436] Mon, 08 November 2004 22:07 Go to previous messageGo to next message
Dave Carlson is currently offline Dave CarlsonFriend
Frank,
Look in the package org.eclipse.wst.xsd.editor.internal.properties.section
where there are classes that provide tabbed view sections and content. This
extends the general tabbed property page implementation from the component
org.eclipse.wst.ui.properties
Dave Carlson
"Frank Dyck" <dyx@gmx.net> wrote in message news:opsg5p3ilz0i05et@celeron...
> the right.
Re: A question about the example xsd editor` s property view?s atrributes tab [message #52530 is a reply to message #52436] Mon, 08 November 2004 22:13 Go to previous message
Keith Chong is currently offline Keith ChongFriend
Member
> the right.
It's located in the org.eclipse.wst.xsd.editor.internal.properties.section
package. The relevant classes are AttributesViewSection,
AttributesViewContentProvider and AttributesViewSectionDescriptor.
Previous Topic:What is the relation of WTP and ibm.zip
Next Topic:Reuse XML editor?
Current Time: Wed Jan 15 06:41:27 GMT 2025
Powered by FUDForum. Page generated in 0.05083 seconds
