Home » Language IDEs » AspectJ » Eclipse Hangs After Installing AJDT
Eclipse Hangs After Installing AJDT [message #51433] |
Thu, 12 May 2005 17:34 |
Originally posted by: aronbock.hotmail.com
I'm running Eclipse 3.0.2 on Win2K Prof. I Installed AJDT via its update
site. However, after install, Eclipse starts up, but then hangs on any
activity.
For example:
1) start eclipse
2) select new Java Project; java project wizard appears
3) enter project name; click next
HANGS: I get a dialog titled "User Operation Is Waiting"; inside I see "New
Java Project" as a task, with a cancel button; of course, if I cancel, the
project does not get created.
I've tried letting this dialog stay up, waiting to complete, even overnight,
but it doesn't complete.
I tried restarting Eclipse with -clean; no difference.
I increased Eclipse vm memory via eclipse.exe -vmargs -mx1024m; still no
difference
I can't even expand Java project nodes in Package Explorer; when I try, I
get that dreaded "User Operation..." dialog. However, this seems to affect
just Java- and Java-related projects, since I *am* able to expand non-Java
projects (Jython projects, PHP projects, etc)
If I uninstall or disable AJDT, these problems go away. When I reinstall or
enable, the reappear.
Would somebody enlighten me, please?
Thanx
--A
Re: Eclipse Hangs After Installing AJDT [message #51517 is a reply to message #51433] |
Fri, 13 May 2005 03:04 |
I'm happy to report this problem has righted itself--what seems to have made
it go away is a good, ol' fashioned machine reboot.
--A
"aron bock" <aronbock@hotmail.com> wrote in message
news:d604jj$ojg$1@news.eclipse.org...
> activity.
Re: Eclipse Hangs After Installing AJDT [message #51543 is a reply to message #51517] |
Fri, 13 May 2005 12:35 |
Sian January Messages: 83 Registered: July 2009 |
Member |
Hi Aron,
I have seen this problem too, however I believe it is fixed in our 1.2.0
RC1 release which is due out very soon.
Sian
> --A
>>Hi,
>>activity.
Re: Eclipse Hangs After Installing AJDT [message #588065 is a reply to message #51433] |
--A
> activity.
Re: Eclipse Hangs After Installing AJDT [message #588073 is a reply to message #51517] |
Member |
Hi Aron,
Sian
> --A
>>Hi,
>>activity.
Current Time: Sat Jul 27 16:14:35 GMT 2024
Powered by FUDForum. Page generated in 0.03102 seconds
