Home » Eclipse Projects » Remote Application Platform (RAP) » Use RAP widgets as WST
Use RAP widgets as WST [message #4519] Thu, 08 March 2007 04:55 Go to next message
Originally posted by: pedro.s.silva.criticalsoftware.com
I' trying to create custom RAP widgets to extend VE so its possible to
create some interfaces with drag and drop but I have some doubts it will
work.
For instance a simple SWT that creates a container goes like this:
package test.ui;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.widgets.Composite;
public class Teste extends Composite {
public Teste(Composite parent, int style) {
super(parent, style);
initialize();
private void initialize() {
setSize(new Point(300, 200));
setLayout(new GridLayout());
But if I do the same with RAP get an error in the VE. The code for RAP
is like this:
package test.ui;
import org.eclipse.rap.rwt.graphics.Point;
import org.eclipse.rap.rwt.layout.GridLayout;
import org.eclipse.rap.rwt.widgets.Composite;
initialize();
The error I got is a red cross in the VE preview pane saying:
java.lang.NoSuchethodException(org.eclipse.rap.rwt.widgets.C omposite. <init>())
Re: Use RAP widgets as WST [message #4659 is a reply to message #4519] Thu, 08 March 2007 07:29 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
thanks for testing RAP. Unfortunately I am not familiar with VE. I have
tested your class within the RAP demo and it seemed to work fine. Does VE
support to use a library like RAP?
Frank Appel
"Pedro Silva" <pedro.s.silva@criticalsoftware.com> schrieb im Newsbeitrag
news:esomir$od6$1@utils.eclipse.org...
> work.
> package test.ui;
> initialize();
> But if I do the same with RAP get an error in the VE. The code for RAP is
> like this:
> package test.ui;
> initialize();
Re: Use RAP widgets as WST [message #4796 is a reply to message #4659] Thu, 08 March 2007 09:38 Go to previous messageGo to next message
Visual Editor Project is a eclipse plugin that allows the build of GUI
in a drag and drop manner. It supports AWT, SWING, SWT and RCP. It comes
very handy to develop the basic interface and manage the several
widgets, placement, etc ...
In the meanwhile I've been thinking that probably it doesn't :( Because
the VE expects java classes and not a library that converts java into
JavaScript, right? The preview pane that draws the different widgets and
allows the interaction with them, would have to be capable of loading
some servlet server in the background in order to preview the RWT
components. At least I think...
What do you think?
Any plans to have a designer plugin or support of RWT by Visual Editor
Project ?
Pedro Silva
Frank Appel wrote:
> Regards
> Frank Appel
>> work.
>> package test.ui;
>> initialize();
>> like this:
>> package test.ui;
>> initialize();
Re: Use RAP widgets as WST [message #5722 is a reply to message #4796] Mon, 12 March 2007 19:21 Go to previous message
Originally posted by: jkrause.innoopract.com
Hi Pedro,
Having VE support for RAP would be really cool. We will look into this
topic in the next couple of weeks.
Jochen
> What do you think?
> Project ?
> Pedro Silva
> Frank Appel wrote:
>> have tested your class within the RAP demo and it seemed to work fine.
>> Does VE support to use a library like RAP?
>> Regards
>> Frank Appel
>> Newsbeitrag news:esomir$od6$1@utils.eclipse.org...
>>> Hi,
>>> to create some interfaces with drag and drop but I have some doubts
>>> it will work.
>>> package test.ui;
>>> initialize();
>>> RAP is like this:
>>> package test.ui;
>>> initialize();
Previous Topic:Some doubts
Next Topic:Getting URL Paramter
Current Time: Wed Nov 05 17:14:20 EST 2025
Powered by FUDForum. Page generated in 0.03466 seconds
