<?php tags and bookmarks [message #51222] |
Thu, 13 September 2007 19:21 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: ryan.gametrailers.com
I believe this is a code assist issue but I'm pretty new to eclipse and pdt
and I can't figure out how to stop auto-inserting "<?php ?>" every time I
type "<?", which makes it very frustrating to use the shorthand echo syntax
I've got the All-in-one S20070826-M3
Anyone know how to disable that feature?
Also, unrelatedly, is there a trick to enabling bookmarks? The option to add
them is always greyed out in every file I've opened.
Thanks a lot for any help!
- Ryan
Re: <?php tags and bookmarks [message #51274 is a reply to message #51248] |
Thu, 13 September 2007 20:03 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Micha,
I realize it's not recommended, but this code doesn't need to be portable
(at least to anywhere I don't have control over the config) and generating
XML isn't a concen either so it's a useful shortcut. Do you know if there's
a way to turn that off?
Re: <?php tags and bookmarks [message #51723 is a reply to message #51274] |
Fri, 14 September 2007 09:23 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: pavel.kunc.google.com
the latest RC1 release doesn't put <?php ?> but <? ?> by default... Which
is what you need but for me it's really unconfortable.
And I also would like to know if there's some settings for it.
Pavel
On Thu, 13 Sep 2007 22:03:53 +0200, Ryan <ryan@gametrailers.com> wrote:
> Micha,
> generating
> there's
Re: <?php tags and bookmarks [message #52786 is a reply to message #51816] |
Tue, 18 September 2007 22:57 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Thanks! I didn't have that option in the version I had at the time, but
upgrading to the new release added it in.
Any idea about not being able to add bookmarks? It's still greyed out for
some reason
"bono" <bono@gmail.com> wrote in message
news:cb4d89048100343f6c14b2ad8f3055c6$1@www.eclipse.org...
> you can enable and disable it using the preference page Preference ->
> PHP -> Editor -> Typing -> Close PHP tag
> Good luck
Re: <?php tags and bookmarks [message #52812 is a reply to message #52786] |
Wed, 19 September 2007 01:56 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Nevermind! I wasn't in a project and didn't realize I need to be. Thanks for
everyone's help
"Ryan" <ryan@gametrailers.com> wrote in message
news:fcpl4i$b62$1@build.eclipse.org...
> some reason
>> Good luck
Re: <?php tags and bookmarks [message #52995 is a reply to message #51816] |
Wed, 19 September 2007 12:17 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
but this is only for on/off PHP tags. But does anybody suffers that in the
stable 1.0 relase by typing <? puts <? ?> instead <?php ?>??
Any way how to set PDT to put <?php ?> again? Or do only I suffer this?
Pavel
> PHP -> Editor -> Typing -> Close PHP tag Good luck
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
FUDForum. Page generated in 0.03667 seconds
