Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Teneo: Hibernate and Arrays as EDataType
| Teneo: Hibernate and Arrays as EDataType [message #51104] |
Wed, 20 September 2006 05:40  |
we have an EMF-model in which we have defined an Integer-Array as EDataType:
<eClassifiers xsi:type="ecore:EDataType" name="IntegerArray"
instanceClassName="int[]"/>
So far everything worked just fine using only the EMF-Framework an
storing everything into XML-Files.
But trying to use the EMF - Hibernate integration results in the
following Exception:
org.hibernate.MappingException: Could not determine type for: int[], for
columns: [org.hibernate.mapping.Column(elt)]
at org.hibernate.mapping.SimpleValue.getType(SimpleValue.java:2 66)
at org.hibernate.mapping.SimpleValue.isValid(SimpleValue.java:2 53)
at org.hibernate.mapping.Collection.validate(Collection.java:26 2)
at org.hibernate.cfg.Configuration.validate(Configuration.java: 988)
org.hibernate.cfg.Configuration.buildSessionFactory(Configur ation.java:1169)
org.eclipse.emf.teneo.hibernate.HbDataStore.buildSessionFact ory(HbDataStore.java:474)
org.eclipse.emf.teneo.hibernate.HbDataStore.initialize(HbDat aStore.java:187)
when calling
HbDataStore hbds = HbHelper.INSTANCE.createRegisterDataStore("test");
hbds.setEPackages(new Package[]{MyPackage.eINSTANCE});
hbds.setHibernateProperties(properties);
hbds.initialize(); // <- this throws the Exception
Is this a Bug, are we doing anything wrong, is there a possible workaround ?
greetings,
Hans
| Re: Teneo: Hibernate and Arrays as EDataType [message #51243 is a reply to message #51104] |
Wed, 20 September 2006 11:12   |
Hi Hans,
Arrays are not yet supported (elists are). If you want you can enter a bugzilla to give an extra
hint that support for arrays (of primitive types) is important.
As a workaround you can try to manually adapt a generated hibernate.hbm.xml. The hibernate.hbm.xml
is generated with a right click on the .ecore file and then select the submenu under teneo.
gr. Martin
Hans Mueller-Dieckert wrote:
> EDataType:
> at
> at
> at
> at
> when calling
> workaround ?
> greetings,
> Hans
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: Teneo: Hibernate and Arrays as EDataType [message #51435 is a reply to message #51243] |
Thu, 21 September 2006 08:24   |
Hi Martin,
thank you for your answer! I've just made a bugzilla entry.
Within this I've also described a problem with EByteArray, which is a
EMF-predefined EDataType. I think this is a related problem.
greetings,
Hans
Martin Taal schrieb:
> Hi Hans,
> bugzilla to give an extra hint that support for arrays (of primitive
> hibernate.hbm.xml. The hibernate.hbm.xml is generated with a right click
> gr. Martin
>> EDataType:
>> for columns: [org.hibernate.mapping.Column(elt)]
>> at
>> at
>> at
>> at
>> when calling
>> workaround ?
>> greetings,
>> Hans
| Re: Teneo: Hibernate and Arrays as EDataType [message #52195 is a reply to message #51435] |
Fri, 22 September 2006 10:06   |
Hi Hans,
Support for arrays has been added in the version in cvs and will be available in the next build
(probably next week).
Other remarks:
- Only primitive type arrays are supported.
- Arrays are currently persisted in a separate table (so not serialized in one column/field).
- A byte array can be persisted as a blob using the lob annotation from jpa/ejb3.
This addition is done for both hibernate and jpox.
gr. Martin
> Hi Martin,
> greetings,
> Hans
>> Hi Hans,
>> gr. Martin
>>> Hi,
>>> EDataType:
>>> at
>>> at
>>> at
>>> at
>>> when calling
>>> workaround ?
>>> greetings,
>>> Hans
The Netherlands
| Re: Teneo: Hibernate and Arrays as EDataType [message #52348 is a reply to message #52195] |
Mon, 25 September 2006 05:47  |
Hi Martin,
thanks for the info. I'll give it a try in the next few days.
greetings,
Hans
> Hi Hans,
> available in the next build (probably next week).
> Other remarks:
> jpa/ejb3.
> gr. Martin
| Re: Teneo: Hibernate and Arrays as EDataType [message #591463 is a reply to message #51104] |
Hi Hans,
gr. Martin
> EDataType:
> at
> at
> at
> at
> when calling
> workaround ?
> greetings,
> Hans
The Netherlands
| Re: Teneo: Hibernate and Arrays as EDataType [message #591557 is a reply to message #51243] |
Hi Martin,
greetings,
Hans
> Hi Hans,
> gr. Martin
>> EDataType:
>> at
>> at
>> at
>> at
>> when calling
>> workaround ?
>> greetings,
>> Hans
| Re: Teneo: Hibernate and Arrays as EDataType [message #591793 is a reply to message #51435] |
Hi Hans,
Other remarks:
gr. Martin
> Hi Martin,
> greetings,
> Hans
>> Hi Hans,
>> gr. Martin
>>> Hi,
>>> EDataType:
>>> at
>>> at
>>> at
>>> at
>>> when calling
>>> workaround ?
>>> greetings,
>>> Hans
The Netherlands
| Re: Teneo: Hibernate and Arrays as EDataType [message #591855 is a reply to message #52195] |
Hi Martin,
greetings,
Hans
> Hi Hans,
> Other remarks:
> jpa/ejb3.
> gr. Martin
Current Time: Mon Oct 27 06:05:16 EDT 2025
Powered by FUDForum. Page generated in 0.05671 seconds
