[Jade] Can't get a proxy to the Platform Manager [message #51059] |
Thu, 19 March 2009 13:32 |
Tommaso Messages: 4 Registered: July 2009 |
Junior Member |
Hi, I have a "big" problem, and here it is...
I'm developing a Plugin Project for Eclipse 3.3 and I want to use Jade
(3.6.1 http://jade.tilab.com) with this project. So, I need to start my
Jade agent platform just clicking a button or a menu entry in this
interface, it seems everything so simple but... it doesn't works.
The weirdest thing is that the same code, when executed in a separate "non
pde" project, works fine!
Explanation:
1) If I try to run jade platform from within my eclipse plugin project,
the boot fails.
2) If I create a separate "normal java" project and execute the SAME
snippet of code it boots successfully! I've tried to create a jar library
file with this "working project" and use it inside the plugin one, but
this fails again.
Here it is the stack trace printed when the execution stops:
Mar 19, 2009 10:24:24 AM jade.core.AgentContainerImpl joinPlatform
SEVERE: Some problem occurred while joining agent platform.
jade.core.ProfileException: Can't get a proxy to the Platform Manager
[nested jade.core.IMTPException: Communication failure while starting JADE
Runtime System. Check if the RMIRegistry CLASSPATH includes the RMI Stub
classes of JADE. [nested java.rmi.ServerException: RemoteException
occurred in server thread; nested exception is:
java.rmi.UnmarshalException: error unmarshalling arguments; nested
exception is:
java.lang.ClassNotFoundException: jade.imtp.rmi.ServiceManagerRMI (no
security manager: RMI class loader disabled)]]
at jade.core.ProfileImpl.createPlatformManager(ProfileImpl.java :568)
at jade.core.ProfileImpl.getPlatformManager(ProfileImpl.java:48 1)
at jade.core.ProfileImpl.getServiceManager(ProfileImpl.java:495 )
at jade.core.AgentContainerImpl.init(AgentContainerImpl.java:32 8)
at jade.core.AgentContainerImpl.joinPlatform(AgentContainerImpl .java:464)
at jade.core.Runtime.createMainContainer(Runtime.java:148)
at jade.Boot.<init>(Boot.java:134)
at jade.Boot.main(Boot.java:68)
it.gruppors.phoenix_epp.controller.agent.platform.PlatformLa uncher.bootJade(PlatformLauncher.java:55)
it.gruppors.phoenix_epp.controller.actions.LaunchAgentPlatfo rmAction.run(LaunchAgentPlatformAction.java:42)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at it.gruppors.phoenix_epp.Application.start(Application.java:2 2)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
Nested Exception:
jade.core.IMTPException: Communication failure while starting JADE Runtime
System. Check if the RMIRegistry CLASSPATH includes the RMI Stub classes
of JADE. [nested java.rmi.ServerException: RemoteException occurred in
exception is:
jade.imtp.rmi.RMIIMTPManager.exportPlatformManager(RMIIMTPMa nager.java:286)
at jade.core.ProfileImpl.createPlatformManager(ProfileImpl.java :557)
Nested Exception:
java.rmi.ServerException: RemoteException occurred in server thread;
exception is:
at sun.rmi.server.UnicastServerRef.oldDispatch(UnicastServerRef .java:396)
at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.ja va:250)
at sun.rmi.transport.Transport$1.run(Transport.java:159)
at sun.rmi.transport.Transport.serviceCall(Transport.java:155)
at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTranspo rt.java:535)
sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TC PTransport.java:790)
sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCP Transport.java:649)
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Threa dPoolExecutor.java:885)
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:907)
at java.lang.Thread.run(Thread.java:619)
sun.rmi.transport.StreamRemoteCall.exceptionReceivedFromServ er(StreamRemoteCall.java:255)
sun.rmi.transport.StreamRemoteCall.executeCall(StreamRemoteC all.java:233)
at sun.rmi.server.UnicastRef.invoke(UnicastRef.java:359)
at sun.rmi.registry.RegistryImpl_Stub.bind(Unknown Source)
at java.rmi.Naming.bind(Naming.java:111)
jade.imtp.rmi.RMIIMTPManager.exportPlatformManager(RMIIMTPMa nager.java:237)
Caused by: java.rmi.UnmarshalException: error unmarshalling arguments;
at sun.rmi.registry.RegistryImpl_Skel.dispatch(Unknown Source)
at sun.rmi.server.UnicastServerRef.oldDispatch(UnicastServerRef .java:386)
Caused by: java.lang.ClassNotFoundException:
jade.imtp.rmi.ServiceManagerRMI (no security manager: RMI class loader
disabled)
at sun.rmi.server.LoaderHandler.loadProxyClass(LoaderHandler.ja va:535)
at java.rmi.server.RMIClassLoader$2.loadProxyClass(RMIClassLoad er.java:628)
at java.rmi.server.RMIClassLoader.loadProxyClass(RMIClassLoader .java:294)
sun.rmi.server.MarshalInputStream.resolveProxyClass(MarshalI nputStream.java:238)
at java.io.ObjectInputStream.readProxyDesc(ObjectInputStream.ja va:1531)
at java.io.ObjectInputStream.readClassDesc(ObjectInputStream.ja va:1493)
java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStre am.java:1732)
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java :1329)
at java.io.ObjectInputStream.readObject(ObjectInputStream.java: 351)
FUDForum. Page generated in 0.03316 seconds
