Home » Modeling » TMF (Xtext) » TMF Xtext Getting Started Example
TMF Xtext Getting Started Example [message #50972] Sat, 13 June 2009 16:07 Go to next message
Originally posted by: oba.informatik.uni-kiel.de
Hi all,
I have downloaded this
distribution( http://oaw.itemis.de/openarchitectureware/language=de/660/do wnloads)
to complete this tutorial (http://wiki.eclipse.org/Xtext/GettingStarted).
Until the step called "Content Generation" everything works fine. When I
start workflow-->MyDslGenerator.mwe as a workflow, I get the following
console output:
0 [main] INFO eclipse.emf.mwe.core.WorkflowRunner -
9 [main] INFO eclipse.emf.mwe.core.WorkflowRunner - EMF Modeling
Workflow Engine 0.7.0, Build v200906091110
9 [main] INFO eclipse.emf.mwe.core.WorkflowRunner - (c) 2005-2009
openarchitectureware.org and contributors
9 [main] INFO eclipse.emf.mwe.core.WorkflowRunner - running
workflow:
/home/oba/Desktop/oba_workspaces/KIELER_KIT/org.xtext.exampl e.mydsl.generator/src/workflow/MyDslGenerator.mwe
268 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering
platform uri '/home/oba/Desktop/oba_workspaces/KIELER_KIT'
748 [main] INFO e.core.container.CompositeComponent -
DirectoryCleaner: cleaning directory 'src-gen'
749 [main] INFO ipse.emf.mwe.utils.DirectoryCleaner - Cleaning
/home/oba/Desktop/oba_workspaces/KIELER_KIT/org.xtext.exampl e.mydsl.generator/src-gen
749 [main] INFO e.core.container.CompositeComponent - MweReader:
loading file from classpath:/model/MyModel.mydsl
969 [main] INFO e.core.container.CompositeComponent - Generator:
generating 'templates::Template::main FOR model' => []
1001 [main] ERROR eclipse.emf.mwe.core.WorkflowRunner - no viable
alternative at character ';' on line 15
org.eclipse.internal.xtend.xtend.parser.ParseException: no viable
org.eclipse.internal.xpand2.parser.XpandParseFacade$3.handle Error(XpandParseFacade.java:77)
org.eclipse.internal.xpand2.parser.XpandParseFacade$1.report Error(XpandParseFacade.java:57)
at org.antlr.runtime.Lexer.nextToken(Lexer.java:119)
org.antlr.runtime.CommonTokenStream.fillBuffer(CommonTokenSt ream.java:119)
at org.antlr.runtime.CommonTokenStream.LT(CommonTokenStream.jav a:238)
org.eclipse.internal.xpand2.parser.XpandLocationAddingParser .start(XpandLocationAddingParser.java:43)
org.eclipse.internal.xpand2.parser.XpandLocationAddingParser .template(XpandLocationAddingParser.java:289)
org.eclipse.internal.xpand2.parser.XpandParseFacade.file(Xpa ndParseFacade.java:44)
org.eclipse.internal.xpand2.parser.XpandParseFacade.file(Xpa ndParseFacade.java:31)
org.eclipse.xpand2.XpandExecutionContextImpl$1.parse(XpandEx ecutionContextImpl.java:92)
org.eclipse.xtend.expression.ResourceManagerDefaultImpl.load Resource(ResourceManagerDefaultImpl.java:70)
org.eclipse.xpand2.XpandExecutionContextImpl.findTemplate(Xp andExecutionContextImpl.java:193)
org.eclipse.xpand2.XpandExecutionContextImpl.findTemplate(Xp andExecutionContextImpl.java:186)
org.eclipse.xpand2.XpandExecutionContextImpl.findDefinition( XpandExecutionContextImpl.java:145)
org.eclipse.internal.xpand2.ast.ExpandStatement.invokeDefini tion(ExpandStatement.java:174)
org.eclipse.internal.xpand2.ast.ExpandStatement.evaluateInte rnal(ExpandStatement.java:167)
at org.eclipse.internal.xpand2.ast.Statement.evaluate(Statement .java:39)
at org.eclipse.xpand2.Generator.invokeInternal2(Generator.java: 334)
org.eclipse.xtend.expression.AbstractExpressionsUsingWorkflo wComponent.invokeInternal(AbstractExpressionsUsingWorkflowCo mponent.java:191)
org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invok e(AbstractWorkflowComponent.java:118)
org.eclipse.emf.mwe.core.container.CompositeComponent.intern alInvoke(CompositeComponent.java:101)
org.eclipse.emf.mwe.core.container.CompositeComponent.invoke (CompositeComponent.java:86)
org.eclipse.emf.mwe.core.WorkflowRunner.executeWorkflow(Work flowRunner.java:412)
at org.eclipse.emf.mwe.core.WorkflowRunner.run(WorkflowRunner.j ava:292)
at org.eclipse.emf.mwe.core.WorkflowRunner.main(WorkflowRunner. java:239)
1002 [main] ERROR eclipse.emf.mwe.core.WorkflowRunner - [ERROR]: no
viable alternative at character ';' on line 15(Element: EXPAND
templates::Template::main FOR model; Reported by: Generator: generating
'templates::Template::main FOR model' => [])
I really would appreciate it, when someone knows what is going on here
for I have no idea. I have been sitting at my desk for hours to no avail...
Thanks in advance
oba
Re: TMF Xtext Getting Started Example [message #51084 is a reply to message #50972] Sun, 14 June 2009 10:12 Go to previous messageGo to next message
Hi oba,
it seems that your system file encoding is different to the one you use
in your workspace. Xpand has these guillemeot characters ('«' and '»'),
whichs code is different from encoding to encoding.
You've therefore to make sure that templates are loaded iusing the same
encoding they have been developed in.
In MyDslGenerator.mwe the encoding can be configured like so:
<component class="org.eclipse.xpand2.Generator">
<metaModel
class="org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel "/>
<!-- add the following -->
<fileEncoding value="UTF-8"/>
<expand value="templates::Template::main FOR model"/>
<genPath value="src-gen"/>
</component>
I've changed the wizard so that the workspace encoding is automatically
configured.
Sven
myName schrieb:
> Hi all,
> console output:
> workflow:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks in advance
> oba
Re: TMF Xtext Getting Started Example [message #51191 is a reply to message #51084] Sun, 14 June 2009 10:44 Go to previous message
Sven Efftinge wrote:
> Hi oba,
> <metaModel
> </component>
Thank you so much! Changing the workspace encoding has solved my
problem. After reading your message, I realized that I have question
marks everywhere in the Template.xpt instead of the guillemeot
characters ('«' and '»').
> I've changed the wizard so that the workspace encoding is > >
automatically
> configured.
I assume, this will be available in the new TMF update. Thanks,
oba
Previous Topic:Problems with imports inside textmodels
Next Topic:Errors in Xtext Grammar File
Current Time: Tue Jul 01 03:51:58 EDT 2025
Powered by FUDForum. Page generated in 0.29031 seconds
