Home » Eclipse Projects » Remote Application Platform (RAP) » Communication between RAP and content of BrowserWidget
Communication between RAP and content of BrowserWidget [message #50730] |
Thu, 04 October 2007 11:37 |
Magnus Konze Messages: 35 Registered: July 2009 |
Member |
i already asked about embedding a texteditor a month ago... Since we
depend on Word documents, i choosed the following way:
I created an applet and embedded Word with the SWT OleFrame widget.
Surprinsingly this works :-)
The applet is deployed on a Tomcat and is displayed with the
BrowserWidget, which is in a modal Dialog.
Now it would be great to have a button, which saves the document AND
closes the dialog.
So far i tried three approaches:
1) close the Dialog/Browser and save the document in the Applets stop()
method
2) close the Dialog/Browser and call the save method of the applet with
javascript (onunload)
Both were unsuccessful, the code, which should save the document is
called, but it seems, that at this point it is too late to save
(OleClientSite.save(...) always returns false, strangely isDirty()
always returns true, even, if i didn't change the document).
(By the way, saving works before i close the Browser.)
3) go to a new URL after saving, this should be recognized by a
LocationListener of the Browser, so that he could be closed
I saw, that there is already a bug report. At the moment the
LocationListener is only called after Browser.setUrl().
Any ideas, how to solve this. Of course i could save and close
independently, but then changes are lost, if you close the Dialog
without saving.
Magnus
Re: Communication between RAP and content of BrowserWidget [message #52199 is a reply to message #50730] |
Wed, 17 October 2007 10:26 |
Originally posted by: fappel.innoopract.com
I would try to save the content of the document (however this is done within
the OleFrame) and after that sending a request to the RAP server
(Unfortunately I don't have much experience with applets, so hopefully there
is a way to do so...). The server could acknowledge the request by sending a
response that closes the dialog. This way the timing issues may be solved.
Ciao
Frank
"Magnus Konze" <bodomchild@web.de> schrieb im Newsbeitrag
news:fe2j94$1hn$1@build.eclipse.org...
> closes the dialog.
> method
> (OleClientSite.save(...) always returns false, strangely isDirty() always
> independently, but then changes are lost, if you close the Dialog without
> saving.
> Thanks
> Magnus
Current Time: Wed Jan 15 07:36:26 GMT 2025
Powered by FUDForum. Page generated in 0.02313 seconds
