Home » Archived » EPF » Export to PDF
Export to PDF [message #50545] Tue, 13 May 2008 12:13 Go to next message
Originally posted by: kelvin.weiss.gmail.com
is possible export to PDF format? or WORD format?
Thank you
Re: Export to PDF [message #50572 is a reply to message #50545] Thu, 15 May 2008 10:57 Go to previous messageGo to next message
It would be quite interesting to export to pdf or work format. But this is
a specific feature of RMC, the IBM's commercial version of EPF Composer.
Nevertheless, I think it is possible to exploit the XML files (especially
the XML export) to generate a PDF file using XSLT and XSL-FO. What do you
think about this? Sure, it would require much more work...
Good cheer!
Re: Export to PDF [message #50968 is a reply to message #50572] Thu, 12 June 2008 16:27 Go to previous messageGo to next message
Hi there,
I have been working on a project where we are writing a SOA developers and
architecture guide. I made a decision to use EPF, as it fits perfectly for
this job. We needed Word and PDF export, so I spent some time fidling with
the XML export to transform it into a suitable XSL:FO format. It works
now, after some major custom made "XML repair" (the export includes a lot
of "broken html" with escaping that must be unescaped etc.
I use the Apache FOP and XFC for the final pdf and RTF/DOCX
transformations.
This way you can configure the final FO that you end up with to suit your
individual needs. I might post the "repair steps" for others to use as a
stepping stone ;)
PS: My current effort took about 50 hours.
Cheers!
Kris
Re: Export to PDF [message #51024 is a reply to message #50968] Fri, 13 June 2008 07:56 Go to previous messageGo to next message
Hi everybody,
Always about PDF export, I tried RMC in order to compare the work with its
specific editing tool and programming from XML export to generate my
proper PDF documents.
When I used RMC trial version, I found the tool a bit heavy to master and
use correctly, and it is difficult to match our specific needs of
presentation. It's sure that it is more easy because you don't need to
program anything, but as I need very specific templates of documents, I
think that RMC reporting tool was not adapted to my expectations.
I'm working on xml Export at present time in order to export part of my
work in PDF.
I'm really interested in your "XML repair". I must say that it is the most
problematic point for PDF export.
Thank you for your help,
Ms.Hampshire
Re: Export to PDF [message #51051 is a reply to message #51024] Sat, 14 June 2008 14:51 Go to previous messageGo to next message
I'm still working on some finishing touches. I will post my work as soon
as it is in a suitable state.
BTW: Does anyone have any experience or knowledge regarding "auto
importing" of pictures referenced in the html (from word)?
Re: Export to PDF [message #51080 is a reply to message #51024] Mon, 16 June 2008 05:33 Go to previous messageGo to next message
I have a small Eclipse Java project which includes the XML export repair
and demonstrates how the repaired XML can be transformed through a series
of steps into a suitable XSL:FO format which can be converted to PDF,
Postscript or some document format (RTF, DOCX, ODT, WML) using either
Apache FOP or XMLmind FC (XFC). How do share this code? Do I have to be a
comitter on the project?
Alternatively post me an email or some otjher localtion I can post/send it
to...
Would be cool to see someone take my efforts a step further!
I have previously been looking into OAW and their EMF toolkit.
I think you could leverage the OAW framework to automate importing
documentation written in Microsoft Word. I imagine you could setup a
folder structure with the word documents saved as (filtered) htm,
including their resources (pictures) and a small metadata file (xml) for
each folder.
Then traverse the whole folder structure and generate the appropriate XMI
model, upload the images into the /ressources folder of the plugin and
reconfigure the internal img hrefs to point to the images in the
/ressources folder. I also noticed, that the Express Word to HTML
converter ignores a lot of special characters if they have not been
properly ecaped (such as danish character æ,ø,å). All the .htm files
should therefore be properly HTML encoded before they are converted.
Kristian
Re: Export to PDF [message #51415 is a reply to message #51080] Fri, 20 June 2008 04:50 Go to previous messageGo to next message
Your work seems really interesting ^^
Please, keep us aware if you publish your work on repairing XML export
from EPF Composer in order to transform it in XSL:FO.
Thanx.
Re: Export to PDF and Import from Word [message #51470 is a reply to message #51415] Fri, 20 June 2008 08:47 Go to previous messageGo to next message
Hi there,
I have successfully created a small Java/Groovy framework using XSLT and
apache FOP and XFC (from Xmlmind.com), that transforms the EPF XML export
to one or more PDFs.
* PDF representing the default view (could be changed to create for all or
a particular view)
* PDF representing each of the major categories of MethodElement, fx a PDF
with all the Tool and ToolMentors (with internal PDF links!)
One could "easily" extend or customize this framework.
I have since then discovered the xsmall framework
https://smallx.dev.java.net/
I'm now in the process of rewriting my "patchwork" framework to something
more usable!
I have also been working on automating the import of content written in
Word, using "save as html". I first took the path of trying to generate
linked .xmi files, but now I am taking the path of generating a single XML
file that follows the EPF XML Schema, to be imported using EPF "import
from XML".
Both methods could potentially work, and each have its own strenghts...
Since I'm as of yet not a committer, I'm not sure where to post any
finished "product". Any ideas?
Kristian
Re: Export to PDF and Import from Word [message #495222 is a reply to message #51470] Wed, 04 November 2009 04:13 Go to previous messageGo to next message
Hi Friends
Plz help me how to export as PDF.
Re: Export to PDF [message #589364 is a reply to message #50545] Thu, 15 May 2008 10:57 Go to previous messageGo to next message
Good cheer!
Re: Export to PDF [message #589501 is a reply to message #50572] Thu, 12 June 2008 16:27 Go to previous messageGo to next message
Hi there,
transformations.
stepping stone ;)
Cheers!
Kris
Re: Export to PDF [message #589512 is a reply to message #50968] Fri, 13 June 2008 07:56 Go to previous messageGo to next message
Hi everybody,
work in PDF.
Ms.Hampshire
Re: Export to PDF [message #589532 is a reply to message #51024] Sat, 14 June 2008 14:51 Go to previous messageGo to next message
Re: Export to PDF [message #589537 is a reply to message #51024] Mon, 16 June 2008 05:33 Go to previous messageGo to next message
to...
each folder.
Kristian
Re: Export to PDF [message #589652 is a reply to message #51080] Fri, 20 June 2008 04:50 Go to previous messageGo to next message
Thanx.
Re: Export to PDF and Import from Word [message #589669 is a reply to message #51415] Fri, 20 June 2008 08:47 Go to previous messageGo to next message
Hi there,
a particular view)
more usable!
from XML".
Kristian
Re: Export to PDF and Import from Word [message #598959 is a reply to message #51470] Wed, 04 November 2009 04:13 Go to previous messageGo to next message
Hi Friends
Re: Export to PDF and Import from Word [message #721668 is a reply to message #589669] Fri, 02 September 2011 09:45 Go to previous messageGo to next message
Hello Kristian
Do you have a solution to export from EPF to Word.
Can you share with us ?
Thank you.
Re: Export to PDF and Import from Word [message #722186 is a reply to message #51470] Sun, 04 September 2011 21:15 Go to previous message
Kristian,
If your code is compliant with the EPL and you are agree to it, then you
can just open a bugzilla and attach your implementation to it for the
EPF team to review it and potentially incorporate it into the next release.
http://www.eclipse.org/legal/eplfaq.php
Cheers!
-A
On 6/20/08 5:47 AM, Kristian Mandrup wrote:
> Hi there,
> export to one or more PDFs.
> or a particular view)
> PDF with all the Tool and ToolMentors (with internal PDF links!)
> something more usable!
> XML file that follows the EPF XML Schema, to be imported using EPF
> "import from XML".
> Kristian
Previous Topic:Question - Issue with Activity Diagram
Next Topic:EPF Wiki Search
Current Time: Tue Sep 16 15:59:54 EDT 2025
Powered by FUDForum. Page generated in 0.06244 seconds
