Re: Hello world for Mylyn monitor [message #50504 is a reply to message #50476] |
Wed, 18 June 2008 19:08 |
Originally posted by: zx.code9.com
> I had indeed a look at UDC and it looked really interesting but as there
> was no "developer guide" on how to use this tool for own RCP
> applications I thought I'll give Mylyn monitor a try. But as I already
> described I didn't find some examples either.
The best you can get right now is probably the code:
http://www.eclipse.org/epp/usagedata/faq.php
There is a Team Project Set file which will give you the code.
You can try to ask the question on the EPP newsgroups where the UDC
project is hosted. I'm sure the EPP guys along with Wayne Beaton can
help you with your needs.
Good luck.
~ Chris
FUDForum. Page generated in 0.04319 seconds
