Home » Eclipse Projects » Plugin Development Environment (PDE) » Target Platform within Eclipse 3.5M6
Target Platform within Eclipse 3.5M6 [message #50377] Sat, 14 March 2009 21:16 Go to next message
Marco  Lehmann-Mörz is currently offline Marco Lehmann-MörzFriend
Member
Hi there,
I created some features and plug-ins and exported them to
D:\exported
with p2 metadata.
The directory contains two directories (features, plugins) and two files
(artifacts.jar, content.jar).
Now I create a target platform in Eclipse 3.5M6. I try to consume this
locally exported features and plug-ins with "Repository and Update Site
Target Provisioner", but it "seems" to contain no features and plug-ins.
Am I missing something?
TIA,
Marco
Re: Target Platform within Eclipse 3.5M6 [message #50435 is a reply to message #50377] Mon, 16 March 2009 19:51 Go to previous messageGo to next message
Ankur Sharma is currently offline Ankur SharmaFriend
Member
Marco Lehmann wrote:
> Hi there,
> D:\exported
> with p2 metadata.
> TIA,
> Marco
You need to create an update site project. Add your features and
plug-ins to it. Build it and export it to file system. Now you should be
able to consume it as "Repository and Update Site". What you were
missing was "site.xml"
hth,
Ankur..
Re: Target Platform within Eclipse 3.5M6 [message #50462 is a reply to message #50435] Mon, 16 March 2009 19:58 Go to previous messageGo to next message
Member
Thanks for your reply, but the current update site for babel
http://download.eclipse.org/technology/babel/update-site/gan ymede/
doesn't have a site.xml and it works perfect.
Sorry,
Marco
>> Hi there,
>> D:\exported
>> with p2 metadata.
>> TIA,
>> Marco
> hth,
> Ankur..
Re: Target Platform within Eclipse 3.5M6 [message #50518 is a reply to message #50462] Mon, 16 March 2009 20:09 Go to previous message
Member
> Sorry,
> Marco
Right. That's because its over http. You can move that d:\exported
behind a webserver and it will work fine for you too. But if you need it
over file:// then site.xml need to be there. Why? Sorry no idea.
regards,
Ankur..
Re: Target Platform within Eclipse 3.5M6 [message #593218 is a reply to message #50377] Mon, 16 March 2009 19:51 Go to previous message
Member
> Hi there,
> D:\exported
> with p2 metadata.
> TIA,
> Marco
hth,
Ankur..
Re: Target Platform within Eclipse 3.5M6 [message #593229 is a reply to message #50435] Mon, 16 March 2009 19:58 Go to previous message
Member
Sorry,
Marco
>> Hi there,
>> D:\exported
>> with p2 metadata.
>> TIA,
>> Marco
> hth,
> Ankur..
Re: Target Platform within Eclipse 3.5M6 [message #593245 is a reply to message #50462] Mon, 16 March 2009 20:09 Go to previous message
Member
> Sorry,
> Marco
regards,
Ankur..
Previous Topic:How do I get the source code?
Next Topic:Contributed Ant task, headless behaviour changed 3.3.2 -> 3.5M5
Current Time: Thu Aug 29 13:00:05 GMT 2024
Powered by FUDForum. Page generated in 0.03073 seconds
