Re: Connection / Shape tool accessibility [message #51531 is a reply to message #50337] |
Sun, 29 December 2002 18:59 |
Originally posted by: hudsonr.us.eye-bee-em.com
"Steven Shaw" <sshaw@rational.com> wrote in message
news:ato44b$s9k$1@rogue.oti.com...
> Hello,
> I apologize if this is documented somewhere - I couldn't find it anywhere.
> When focus is on the palette, is there a keyboard accessible way to create
a
> connection between two shapes (without using the mouse)?
There should be, please open a bugzilla. We can add similar keyboard
support.
> In logic example, you can select the connection tool by pressing space
bar,
> then set the focus back to the keyboard using "Tab", but then the keyboard
> and/or arrows keys seem to be ignored? Is there a key sequence to enter
> accessibility mode similar to the handles accessibility?
> Same goes for regular shape tools - I can select it, but then can't do
> anything else via keyboard.
In 2.0, this was up to the application. For 2.1, the intended solution is
that you Control+C the item from the palette, and Paste it into the diagram.
Then you can adjust the position using the accessible handles. The initial
"constraint" of the pasted item will be up to the application to determine,
probably.
FUDForum. Page generated in 0.02813 seconds
