Home » Archived » Visual Editor (VE) » How can I do plugin that have 2 window (for coding and ui-editing) like in VE
How can I do plugin that have 2 window (for coding and ui-editing) like in VE [message #50297] Thu, 15 July 2004 00:54
Originally posted by: tanut.sanuk.biz
I do my own GUI form editor and then I want to synchronize the form with its
code(.java).
So I must to modify the java code according to the editing form. now my
think:
1. use independent window - one use my GUI editor for .form and one use
eclipse java editor for .java
2. use combine window (like in VE, Jigloo)
by the way if user open two window (.form and .java). when .form editor has
modified .java code, the java editor must change too. And when user has
modify form editor the opened java editor must change too.
What the way that I do that?
Thank you wery much. :)
Tanut Apiwong
ps. my english is little poor -_-''.
Previous Topic:Properties dialog focus
Next Topic:How can I do plugin that have 2 window (for coding and ui-editing) like in VE
Current Time: Fri Apr 25 23:47:04 EDT 2025
Powered by FUDForum. Page generated in 0.02809 seconds
