Home » Archived » M2M (model-to-model transformation) » [ATL] Recognition of design pattern in UML class diagrams
[ATL] Recognition of design pattern in UML class diagrams [message #50148] |
Fri, 29 June 2007 10:32 |
Originally posted by: frederic_thomas_fr.yahoo.fr
In the context of my PhD, I am using ATL to transform UML class diagrams.
I have write a first transformation, nevertheless I need currently to
recognize design pattern in UML class diagrams.
In the litterature, I identify few concrete and implemented approachs. I
have not found such transformation use case in the ATL zoo. I maybe miss
something.
So, I was wondering if someone in the ATL community, have already
described such transformations ?
I am looking forward to your feddbacks in order to write my transformation
in a good way.
Frédéric
Re: [ATL] Recognition of design pattern in UML class diagrams [message #50180 is a reply to message #50148] |
Fri, 29 June 2007 11:23 |
Originally posted by: Hugo.Bruneliere.univ-nantes.fr
Frédéric Thomas a écrit :
Hi Frederic,
> diagrams. I have write a first transformation, nevertheless I need
> currently to recognize design pattern in UML class diagrams.
> something.
> transformation in a good way.
> Frédéric
I don't know if someone has already developed all the steps of such an
approach using ATL but you can find from the ATL use cases page many
different use case concerning UML (such as the "Measuring UML models" or
"Verifying UML profiled models" ones). Maybe it will help you writing
your design-pattern recognition in ATL.
See http://www.eclipse.org/m2m/atl/usecases/
Hugo
Hugo Bruneliere - R&D Engineer
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssiniere
44322 Nantes Cedex 3 - France
office +33 2 51 12 58 10 /\ cell.+33 6 07 42 45 30
EMail: Hugo.Bruneliere@univ-nantes.fr
http://www.sciences.univ-nantes.fr/lina/atl/
Re: [ATL] Recognition of design pattern in UML class diagrams [message #50240 is a reply to message #50148] |
Mon, 02 July 2007 07:43 |
> something.
> Frédéric
just to say that i'm interested by links or papers about *applying*
design patterns to a model with atl. For example transforming a simple
model with a class into a singleton class, ie transforming constructor
to make it private, add a method "getInstance", etc.
(Examples with more complex patterns such as abstract factories or
visitor, or.. will also be appreciated!)
If anyone has such material or ideas for starting, thanks a lot !
Nicolas
Re: [ATL] Recognition of design pattern in UML class diagrams [message #50355 is a reply to message #50240] |
Mon, 02 July 2007 10:55 |
Dennis Wagelaar Messages: 147 Registered: July 2009 |
>> I have not found such transformation use case in the ATL zoo. I maybe
>> miss something.
>> Frédéric
> Nicolas
Here are some examples, albeit complex ones:
http://ssel.vub.ac.be/ssel/research:mdd:casestudies#uml2obse rver_uml2javaobserver
http://ssel.vub.ac.be/ssel/research:mdd:casestudies#uml2abst ractfactory
http://ssel.vub.ac.be/ssel/research:mdd:casestudies#uml2sing leton
Unfortunately, no reverse transformations exist yet.
Dennis
Current Time: Sat Jul 27 16:08:36 GMT 2024
Powered by FUDForum. Page generated in 0.03622 seconds
