Home » Eclipse Projects » Plugin Development Environment (PDE) » Headless Build and Debug Info
Headless Build and Debug Info [message #50140] Wed, 11 March 2009 09:29
Manuel Selva is currently offline Manuel SelvaFriend
Hi all,
After a long fight I was able to generate debug info in my headless build
by setting: "compilerArg=-g" as explained here
http://manuelselva.wordpress.com/2009/03/10/headless-build-f or-ever/
Nevertheless I still dind't understand why setting javacDebugInfo=true
doesn't work !!!
After deep debugging it seems the javacDebugInfo=true is correctly
generated in generated build.xml file for my plug-in but then this info is
not correctly transmitted to the JDT compiler. Trying to generated a
simple ant project calling eclipse jdt compiler to compile a simple Java
class with debug info doesn't work ...
Any help to understand what happen here would be great ;o)
Manu
Previous Topic:headless p2 director application
Next Topic:Headless Build and Debug Info
Current Time: Thu Dec 26 17:37:18 GMT 2024
Powered by FUDForum. Page generated in 0.04380 seconds
