Home » Eclipse Projects » Technology Project and PMC » <Strg>+<Space> doesn't work
<Strg>+<Space> doesn't work [message #50017] Mon, 24 March 2003 13:48 Go to next message
Originally posted by: mikepaulsen.gmx.de
I have a problem with <Strg>+<Space>!
Everytime I press the keys the next line is underlined but nothing else. No
assistent, no completion.
(If I press the dot after an element the completion works fine!!!)
Does anybody have an idea?
Mike
Re: <Strg>+<Space> doesn't work [message #50137 is a reply to message #50017] Tue, 25 March 2003 03:57 Go to previous messageGo to next message
Originally posted by: therier.yahoo.com
The completion is activated using <Ctrl>+<SPACE>
"Mike Paulsen" <mikepaulsen@gmx.de> a
Re: <Strg>+<Space> doesn't work [message #50254 is a reply to message #50137] Tue, 25 March 2003 09:37 Go to previous messageGo to next message
I'm sorry but I'm from Germany and the key is abbreviated <strg> ->
<strg>==<ctrl>
The key is correct but no result!
"Tony Therier" <therier@yahoo.com> schrieb im Newsbeitrag
news:b5p5ik$3iu$1@rogue.oti.com...
Re: <Strg>+<Space> doesn't work [message #50284 is a reply to message #50254] Tue, 25 March 2003 11:08 Go to previous messageGo to next message
Maybe you have defined a wrong key binding....
Re: <Strg>+<Space> doesn't work [message #50339 is a reply to message #50284] Tue, 25 March 2003 12:38 Go to previous message
I don't have changed anything.
Could it be that my pc is to slow???
news:b5puq2$rul$1@rogue.oti.com...
Re: <Strg>+<Space> doesn't work [message #50368 is a reply to message #50339] Tue, 25 March 2003 12:35 Go to previous message
It's true that sometime it is very slow (especially if you type O and
Ctrl+Espace top get Object ;-) )but it finally happends...
Re: <Strg>+<Space> doesn't work [message #591975 is a reply to message #50017] Tue, 25 March 2003 03:57 Go to previous message
Re: <Strg>+<Space> doesn't work [message #592019 is a reply to message #50137] Tue, 25 March 2003 09:37 Go to previous message
<strg>==<ctrl>
Re: <Strg>+<Space> doesn't work [message #592032 is a reply to message #50254] Tue, 25 March 2003 11:08 Go to previous message
Re: <Strg>+<Space> doesn't work [message #592059 is a reply to message #50284] Tue, 25 March 2003 12:38 Go to previous message
Re: <Strg>+<Space> doesn't work [message #592069 is a reply to message #50339] Tue, 25 March 2003 12:35 Go to previous message
Previous Topic:Using Eclipse for a non-IDE application
Next Topic:How do I integrate JDK Java doc into Eclipse
Current Time: Fri Apr 25 21:53:43 EDT 2025
Powered by FUDForum. Page generated in 0.03534 seconds
