Home » Modeling » TMF (Xtext) » OAW to TMF - Scala EMF
OAW to TMF - Scala EMF [message #49994] Thu, 11 June 2009 07:12 Go to next message
I've been reading the OAW to TMF migration document and the comment is
made:
"Also without changing the EMF generator it is inconvenient to use EMF
classes in Scala, since Scala uses a different convention for getter and
setter methods."
Slightly off topic but can someone please elaborate on what you mean here?
I've done some Scala EMF work both with the generated and reflective EMF
classes and found that using Scala is similar to Java but less verbose due
to Scala's type inference. I'm aware of Scala's automatic getter/setter
approach to implementing class attributes as properties. Where is the
inconvenience with EMF?
Re: OAW to TMF - Scala EMF [message #50114 is a reply to message #49994] Thu, 11 June 2009 08:58 Go to previous message
I tried to state that it would be nice to have scala-like accessors in
order to write
foo.myProp instead of foo.getMyProp().
i.e. have methods myProp() and myProp_(PropType)
That's all.
Of course one can use getMyProp and setMyProp as in Java.
I've removed that line, since it's only inconvenient compared to Xtend
not when comparing to Java.
Sven
> made:
> setter methods."
> due to Scala's type inference. I'm aware of Scala's automatic
> getter/setter approach to implementing class attributes as properties.
> Where is the inconvenience with EMF?
Previous Topic:download for RC3 fails
Next Topic:[Xtext] Formatter/Pretty Printer needed
Current Time: Fri Apr 25 19:24:59 EDT 2025
Powered by FUDForum. Page generated in 0.06841 seconds
