Home » Newcomers » Newcomers » Eclipse: HttpServlet cannot be resolve to type, Tomcat: Servlet is working OK
Eclipse: HttpServlet cannot be resolve to type, Tomcat: Servlet is working OK [message #49955] Sat, 09 April 2005 18:16 Go to next message
Originally posted by: lukasz.budnik.vega.eti.pg.gda.pl
Hello.
I'm using (trying to use) Eclipse for writing my servlets but
I keep getting this strange error: 'HttpServlet cannot be resolve to type'
and it point to this line:
'public class MyServlet extends HttpServlet {'
When I'm using command line javac everything is OK and Servlet works fine
in Tomcat 5.5.7
I'm using jdk1.5.0_02 - 5.0 and Eclipse Version: 3.1.0 Build id:
I20050219-1500
jdk and Tomcat are new (updated today from apache.org and sun.com)
is it my fault? or is it Eclipse's?
what should I do?
thanks in advance
best regards
Luke
Re: Eclipse: HttpServlet cannot be resolve to type, Tomcat: Servlet is working OK [message #50002 is a reply to message #49955] Sat, 09 April 2005 18:31 Go to previous messageGo to next message
Originally posted by: myersj.gmail.com
Luke,
Have you added the servlet libraries provided by Tomcat to your Eclipse
project? HttpServlet is most likely not in your build path in Eclipse.
You'll need to get the jar that contains that class and add it as a
library to your Eclipse project.
Hope this helps,
- Jeff
Luke wrote:
> Hello.
> fine in Tomcat 5.5.7
> I20050219-1500
> what should I do?
> thanks in advance
> best regards
> Luke
Re: Eclipse: HttpServlet cannot be resolve to type, Tomcat: Servlet is working O [message #50207 is a reply to message #50002] Sun, 10 April 2005 04:51 Go to previous messageGo to next message
I'm not that newbie ;-)
I've create libraries for my servlet project:
/usr/jakarta-tomcat-5.5.7/server/lib and
/usr/jakarta-tomcat-5.5.7/common/lib
Eclipse sees that packages - for example code completition works fine
but there's an error on that first line - the definition of class
extending HttpServlet.
best regards
Luke
Re: Eclipse: HttpServlet cannot be resolve to type, Tomcat: Servlet is working O [message #50237 is a reply to message #50207] Sun, 10 April 2005 07:23 Go to previous message
OK it was Eclipse error.
I renamed the file to xxx.java and then back to MyServlet.java and error
disappeared.
weird behaviour
best regards
Luke
Previous Topic:XDoclet dies on stack overflow
Next Topic:md5sum -c eclipse-SDK-3.02-win32.zip.md5 failed
Current Time: Fri Apr 25 00:47:02 EDT 2025
Powered by FUDForum. Page generated in 0.08388 seconds
