Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » How do I configure the Ruby Runtime for TestCases
Re: How do I configure the Ruby Runtime for TestCases [message #4576 is a reply to message #4368] |
Mon, 21 May 2007 06:01 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: mikhail.kalugin.xored.com
Hi, Mark.
As I remember, you had already asked this question some time ago. I had
answered at that
time(http://dev.eclipse.org/mhonarc/lists/dltk-dev/msg00007.html). So,
was my thoughts there useful? If not, please say and I'll be grad to
help with a solution.
Mark Howe wrote:
> How can I configure a Ruby Interpreter when running unit tests. I'm
> extending AbstractModelTests and creating a new runtime workspace,
> copying a project from my test/workspace into the runtime workspace. All
> that works fine, any paths set up in the project are fine, but the
> interpreters are defined in the workspace so they don't show up for the
> unit test. So I need to setup the ruby runtime programatically.
> Any help would be greatly appreciated.
> Thanks Mark
Re: How do I configure the Ruby Runtime for TestCases [message #4715 is a reply to message #4576] |
Wed, 23 May 2007 02:05 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Mark Howe![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=mark.howe%40codegear.com) Messages: 14 Registered: July 2009 |
Junior Member |
Hi Mikhail, sorry I didn't see your previous post for some reason (guess I was looking at the old
newsgroup). Thanks for the info, will give this a go and see if I need any more help
Mark
Mikhail Kalugin wrote:
> Hi, Mark.
> answered at that
>> All that works fine, any paths set up in the project are fine, but the
>> the unit test. So I need to setup the ruby runtime programatically.
>> Thanks Mark
Re: How do I configure the Ruby Runtime for TestCases [message #4853 is a reply to message #4576] |
Thu, 24 May 2007 19:09 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Junior Member |
Hi Mikhail, another test related question.
If I get SourceMethod in a test case and then ask for a SourceReflementInfo, it's always null
(whereas asking a SourceModule works fine). I must not be intializing the test project correctly,
any idea what that might be (sorry how little context there is for the question :>).
Mark
> Hi, Mark.
> answered at that
>> Thanks Mark
Re: How do I configure the Ruby Runtime for TestCases [message #4991 is a reply to message #4853] |
Tue, 29 May 2007 21:29 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Junior Member |
I figured out what I was doing wrong, thanks
> SourceReflementInfo, it's always null (whereas asking a SourceModule
> works fine). I must not be intializing the test project correctly, any
> question :>).
> Thanks
> Mark
>> Hi, Mark.
>> had answered at that
>>> the interpreters are defined in the workspace so they don't show up
>>> for the unit test. So I need to setup the ruby runtime programatically.
>>> Thanks Mark
Current Time: Wed Jul 24 13:38:14 GMT 2024
Powered by FUDForum. Page generated in 0.03622 seconds
