Chart Error [message #49897] |
Wed, 22 June 2005 20:50 |
Originally posted by: gauravengg.hotmail.com
I am getting this Error when I try to display a Chart & Listing.
Error1:Fails to handle ExtendedItem null:null
although both the chart and table is being displayed..also there is
<undefined> shown on x - axis on right side.
i just placed the values from data set into table and configured the chart
properties to include the data.
could any1 please advise me why the error is there...think i am not
configuring properly,,that ' why there is <undefined> tag on x - axis..
<undefined> label Chart Y axis [message #49967 is a reply to message #49897] |
Wed, 22 June 2005 21:54 |
I am getting a <undefined> tag on Y axis in the Chart though everything is
dispalyed...
Kindly advise as to what did i miss configuring or how can i fix this..
thanx
Re: Chart Error [message #50063 is a reply to message #49897] |
Wed, 22 June 2005 22:29 |
Originally posted by: mpadhye.actuate.com
wal,
Does this happen if you create a blank report and insert the same chart
in it (without the table)?
Does this happen for a particular chart type or for any chart?
-Milind
> chart properties to include the data.
Re: Chart Error [message #50669 is a reply to message #50063] |
Thu, 23 June 2005 18:09 |
thanx,,,that undefined problem is fixed.
ye but i am still getting th eother error when i do a chart and listing
type..
but when i create a simple reoprt and insert a chart from palette..it
works ok...
regards
Re: Chart Error [message #51325 is a reply to message #50669] |
Fri, 24 June 2005 14:41 |
wal,
Can you add a Bugzilla entry for this problem? Add as much information
as possible (versions, sample report etc.). This way, we will be able to
reproduce and fix any problems quickly.
Milind
> type..
> works ok...
> regards
FUDForum. Page generated in 0.24888 seconds
