Re: different line numbers in xdebug view [message #49798 is a reply to message #49768] |
Sun, 09 September 2007 10:26 |
Originally posted by: dkel50.hotnospmail.com
Have you tried the official release of 2.0 of xdebug ? There
may be some bug fixes that resolve this.
If not, can you provide an example script demonstrating the problem ?
Also which level of php are you using ?
Cheers
Dave Kelsey
Oliver Trosien wrote:
> Hello Newsgroup,
> I am curious if I am the only one with the following debugging
> problem:
> Quite often the line highlighted in debug view is not the
> line the script is currenly executing.
> I am using the most recent PDT build and xdebug2.0.0 RC4
> Has anyone seen this behaviour? Should I open a bug report?
> Greetings,
> Oliver
FUDForum. Page generated in 0.03468 seconds
