Home » Newcomers » Newcomers » listener : solved
listener : solved [message #49715] Sat, 09 April 2005 03:14
Originally posted by: problem.solved.forNow
hi-
i used this code. now i can run any query against any db in the database
entering sql in a text control and displaying the result in a table control
after i push a button.
i am scamming this code and will give credit to the author(s).
once in awhile i have to make a change here or there.
final Button testButton = new Button(shell,SWT.PUSH);
testButton.addSelectionListener(new SelectionListener(){
public void widgetSelected(SelectionEvent e){
System.out.println("go to bed");
public void widgetDefaultSelected(SelectionEvent e){
i found this link someone else posted and it is a huge help.
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-swt-
home/dev.html#snippets
thanks everyone,
jim
Previous Topic:error message with listener
Next Topic:Improve C# Plugin, how to supply command line parameters to Mono mcs.exe
Current Time: Wed Jul 02 09:20:46 EDT 2025
Powered by FUDForum. Page generated in 0.10113 seconds
