Home » Eclipse Projects » Subversive » Native JavaHL: Can't find dependent libraries
Native JavaHL: Can't find dependent libraries [message #49701] Mon, 20 July 2009 13:45 Go to next message
Did a clean install of Eclipse 3.5 + Subversive (had been using Eclipse
3.4 + Subversive without problems before). Now I'm having two problems:
1. If I use the "SVN Kit (SVN/1.6.2 SVNKit/1.3.0)" connector, new
resources that were added to a repository are not picked up when
synchronizing.
2. Can't select the "Native JavaHL" connector: "Native JavaHL
(0x00100000): Cannot load libraries: C:\Program
Files\Eclipse\plugins\org.polarion.eclipse.team.svn.connecto r.javahl16.win32_2.2.1.I20090708-1500\libaprutil-1.dll:
Can't find dependent libraries)"
Re: Native JavaHL: Can't find dependent libraries [message #49731 is a reply to message #49701] Mon, 20 July 2009 16:56 Go to previous messageGo to next message
Hi Eric,
does this description help you?
http://www.vogella.de/articles/EclipseSubversive/article.htm l
Best regards, Lars
> synchronizing.
http://www.vogella.de/ - Eclipse plugin and Eclipse RCP Tutorials
Re: Native JavaHL: Can't find dependent libraries [message #49761 is a reply to message #49731] Mon, 20 July 2009 17:03 Go to previous messageGo to next message
I have the latest versions of all connectors etc installed...
For the time being I'll just use this description:
http://subclipse.tigris.org/install.html
Re: Native JavaHL: Can't find dependent libraries [message #49791 is a reply to message #49761] Tue, 21 July 2009 01:36 Go to previous messageGo to next message
Hi Eric,
subclipse and subversive are different approaches to svn . I believe
using a installation guide for subclipse will not work if you want to
setup subversive.
Best regards, Lars
Re: Native JavaHL: Can't find dependent libraries [message #49906 is a reply to message #49791] Wed, 22 July 2009 20:18 Go to previous messageGo to next message
> setup subversive.
Well, after wasting too much time and not hearing about a solution to the
problem posted here, I decided I no longer wanted to setup Subversive...
Subclipse appears to be working fine with both JavaHL and SVNKit; not sure
what cased Subversive to break (I'm assuming it's still working fine for
others).
Re: Native JavaHL: Can't find dependent libraries [message #49934 is a reply to message #49906] Thu, 23 July 2009 11:35 Go to previous messageGo to next message
Just revisited Subversive after I had problems like this one almost one
year ago - seems the problems are still the same, sadly.
I get the exact same error on a fresh 3.5 install on Win32 (Vista SP2)
Galileo JEE, installed according to howto and also looked at Lars' article.
There is some dependency on libapr that is simply not fulfilled by any of
the plugins.
When installing the 1.5-version (NativeWin32 1.5 + JavaHL 1.5), it works,
but not with 1.6.
Re: Native JavaHL: Can't find dependent libraries [message #50014 is a reply to message #49934] Fri, 24 July 2009 00:58 Go to previous messageGo to next message
Note: Native JavaHL 1.6 has been working fine for me on 3.5 until a couple
of days ago when I auto-updated to 2.2.1.I20090708-1500. Now I get this
error. I have seen some posts that suggest that having both 1.5 and 1.6
installed concurrently can cause similar problems, but this is not the
case for me.
I am going to try and back out that update.
Re: Native JavaHL: Can't find dependent libraries [message #50045 is a reply to message #50014] Fri, 24 July 2009 01:21 Go to previous messageGo to next message
> case for me.
Grr. It seems that the old version is no longer available from the update
site. Changed to Native JavaHL 1.5 and it works fine now (although I had
to blow away my existing working copy and recheck out). Suggest there
might be a problem with the 1.6 version.
Re: Native JavaHL: Can't find dependent libraries [message #373612 is a reply to message #50045] Wed, 29 July 2009 11:12 Go to previous messageGo to next message
Originally posted by: mailpgrupos.netcabo.pt
I have this problem too. Is there any possibility of correcting this bug?
S
Re: Native JavaHL: Can't find dependent libraries [message #481001 is a reply to message #49701] Wed, 19 August 2009 06:33 Go to previous message
1. Problem with SVN Kit
You can fire a bug on Bugzilla with detailed steps how to reproduce the
problem.
2. Problem with JavaHL:
You don't need to install several JavaHL connectors simultaneously, only one
of them should be installed.
JavaHL connector consists of two parts: native implementation and Win32
binaries, e.g. Native JavaHL 1.6 Implementation and JavaHL 1.6.0 Win32
binaries, please be sure that you installed both.
For more details how to install Subversive, please visit its download page:
http://www.eclipse.org/subversive/downloads.php.
Also note that starting from version 0.7.8.I20090808-1900 you can install
connectors from Connector Discovery feature:
http://www.eclipse.org/subversive/documentation/teamSupport/ connectors_discovery.php
> synchronizing.
Previous Topic:How to relocate the location of my projects
Next Topic:PSF files : specify revision number of a project
Current Time: Wed Apr 16 10:57:56 EDT 2025
Powered by FUDForum. Page generated in 0.02731 seconds
