Re: Problem getting all files/folders when unpack="true" [message #49650 is a reply to message #49558] |
Fri, 06 March 2009 15:45 |
On 3/5/2009 8:20 PM, Kent Beck wrote:
> I have a plugin (JUnit Max, to be precise) that needs to unpack when it
> is installed. (It contains a jar file and you can't have a jar in a
> jar.) I set the "Unpack plugin archive after the installation" checkbox
> in the feature.xml GUI (I also tried manually setting unpack="true"
> feature.xml). In either case, the plugins directory contains a directory
> for my plugin, but the icons directory inside my plugin does not appear
> in the resulting directory. The icons directory and its contents are
> there in the plugin jar file.
It's just a shot in the dark, but have you checked that the icons
directory is included in build.properties (in the bin.includes
property)? The Build tab of the manifest/plugin.xml editor allows easy
configuration.
Hope this helps,
Eric
FUDForum. Page generated in 0.05214 seconds
