JET headless bulid [message #49404] |
Thu, 11 September 2008 12:26 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Is it possible to automate JET builds (headlessly) so that we don't have
to check in JET-generated code? Someone on our team last year claims to
have researched the topic and hit a dead end, but that was a while ago
and he is no longer with our team.
Any advice in this area is much appreciated.
Eric
Re: JET headless bulid [message #49463 is a reply to message #49404] |
Thu, 11 September 2008 13:22 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Paul Elder![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=pelder%40ca.ibm.com) Messages: 849 Registered: July 2009 |
Eric:
JET does include an ANT task for compiling JET templates. I'll give a quick
rundown of how the task is used in PDE build, but I'll conclude with an
important caveat.
Let's start with the ANT task. Here's an example:
<jet.compile project="my.jet.project" destdir="jet2java" >
<srcdir dir="." includes="templates/**/*.jet"/>
</jet.compile>
The task requires the Eclipse ANT runner (you typically are using this for
PDE build anyhow). The Eclipse instance being used for the build must have
JET and EMF installed (JET requires EMF). The best way to get PDE build to
invoke the ant task is to use a 'custom Build Callbacks' file. Do the
following:
Modify build.properties to include the following line:
customBuildCallbacks=customBuildCallbacks.xml
This tells PDE build to use customBuildCallbacks.xml (an ANT build file) for
call packs. The path to the file is relative to the project.
There is a template for this file in the org.eclipse.pde.build plug-in.
Here's the path for Eclipse 3.4.0:
org.eclipse.pde.build_3.4.0.v20080604\templates\plugins\cust omBuildCallbacks.xml
There are lots of stub tasks in the template. If you're doing the 'normal'
JET project, where PDE is building a JAR'd plugin, then you want to add the
following to the template:
<!-- Steps to do before the compilation target
<!-- Available parameters
<!-- source.foldern : n = 1 ... N, the source
<!-- target.folder : where the results of the compilation
<!-- @dot.classpath : name = name of the compilation target.
<!-- reference to the classpath
<target name="pre.@dot">
<jet.compile project="---- your project name goes here---" destdir="----
JETs Java source folder goes here.. e.g. jet2java----" >
</jet.compile>
</target>
<!-- Steps to do during the compilation target @dot, after the
mpile -->
<!-- but before
<target name="post.compile.@dot">
</target>
<!-- Steps to do after the compilation target
<!-- jar.location - the location of the compilation
<target name="post.@dot">
</target>
You can test all of this from the workspace by changing using something
other than jet2java for destdir, and then using the Export deployable
plug-in wizard.After the build, you should see the generated Java classes in
the destdir folder.
======== CAVEAT - Please read ========
Now here's the important Caveat. The jet.compile ANT task has an important
design flaw - it assumes that PDE build is compiling plug-ins that are
located in a workspace. In the real world, this is often not the case. All
the details are available on this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=210447.
The bottom line is that if you want this to work, you have to:
1) make sure that your build somehow gets the JET projects into the
workspace being used by the PDE ANT runner.
2) make sure that any custom JET tags used by the JET projects are also
projects in that workspace.
I would certainly welcome ideas/help on getting this to work. There are two
possible routes:
1) Fix it the right way, which means me making some changes to how the JET
compiler, the jet.compile ant task and perhaps the projects 'manifest'
information. This, unfortuntately will take some time - I'm hoping to get
something done for Galileo (i.e. June 2009).
2) Figure out some hacks. I haven't delved deeply in to the mysteries of PDE
build, but it seems to me that, after PDE build has checked out the projects
to be built, some custom code could be added to import them into the
workspace being used by PDE build. Conceptually, this is easy. Practically,
I don't know how to do it.
Paul
Re: JET headless bulid [message #49494 is a reply to message #49463] |
Thu, 11 September 2008 13:42 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Thanks, Paul. It is good to hear that there is a path forward (even if
it is a bit of a rocky path).
Regarding the "projects in workspace" caveat:
a) I don't really understand the distinction or meaning of "it assumes
that PDE build is compiling plug-ins that are located in a workspace."
Can you explain the limitation with an example in more detail?
b) Have you tried the alternate solution suggested by David Lear in the bug:
> You could always use the EMF JET compile in customBuildCallbacks.xml.
> For example:
> <emf.JETCompiler
> templateFile="./templates/library_entry_point.cjet"
> sourceDirectory="generated"/>
> </target>
> This works without the project being in the workspace.
Thanks again for this valuable info. I think it would make a good wiki
page, but am not sure where to insert the page (and I think you deserve
the authorship credit anyway). If you have a chance to put this info on
the wiki, please post the page name so I can bookmark it.
Eric
Paul Elder wrote:
> Eric:
> important caveat.
> </jet.compile>
> following:
> </jet.compile>
> </target>
> mpile -->
> <!-- but before
> </target>
> </target>
> the destdir folder.
> possible routes:
> Paul
FUDForum. Page generated in 0.03385 seconds
