Home » Modeling » GMF (Graphical Modeling Framework) » Multiple links in mindmap example
Multiple links in mindmap example [message #49379] Sun, 17 September 2006 05:42 Go to next message
Originally posted by: alexander.schwartzonline.de
I have a problem with GMF (version 1.0.0.v200606261119 from the Callisto
update site) and the mindmap example (from the zip from the mindmap
tutorial page):
When I insert an Includes connection between two Topic nodes
I obtain two diagram links instead of a single one.
One has the correct label 'includes' the other one is unlabeled.
Any hints?
Alex
Re: Multiple links in mindmap example [message #49617 is a reply to message #49379] Mon, 18 September 2006 05:44 Go to previous messageGo to next message
This issue is discussed previously. Please search for this thread "Link
Mapping - Single Connector for all Figures"
It will help.
Madanagopal.
On Sun, 17 Sep 2006 11:42:59 +0200, Alexander Schwartz
<alexander@schwartzonline.de> wrote:
> tutorial page):
> Any hints?
> Alex
Re: Multiple links in mindmap example [message #50401 is a reply to message #49617] Mon, 18 September 2006 18:34 Go to previous messageGo to next message
Hi Madanagopal,
> It will help.
Thanks for your hint. The suggested solution works: only one link is
inserted as expected.
But there is a little problem left; my link object is missing its label.
The diagram link souhld look like as follows.
<edges xmi:type="notation:Edge" xmi:id="_0MUmMEdiEdu3qOjSl4MqCA"
type="3003" source="_YeaUsEdiEdu3qOjSl4MqCA"
target="_YSYq4EdiEdu3qOjSl4MqCA">
<children xmi:type="notation:Node" xmi:id="_0MUmNUdiEdu3qOjSl4MqCA"
type="4003">
<layoutConstraint xmi:type="notation:Location"
xmi:id="_0MUmNkdiEdu3qOjSl4MqCA" y="40"/>
</children>
<styles xmi:type="notation:RoutingStyle"
xmi:id="_0MUmMUdiEdu3qOjSl4MqCA"/>
<styles xmi:type="notation:FontStyle"
xmi:id="_0MUmMkdiEdu3qOjSl4MqCA"/>
<styles xmi:type="notation:LineStyle"
xmi:id="_0MUmM0diEdu3qOjSl4MqCA"/>
<element xmi:type="simpleusecase:UseCaseAssociation"
href="default2.simpleusecase#//@associations.1"/>
<bendpoints xmi:type="notation:RelativeBendpoints"
xmi:id="_0MUmNEdiEdu3qOjSl4MqCA" points="[11, -23, -54, 155]$[115, -176,
50, 2]"/>
<sourceAnchor xmi:type="notation:IdentityAnchor"
xmi:id="_0MUmN0diEdu3qOjSl4MqCA" id="(0.78,0.575)"/>
</edges>
Unfortunately the <children> element is not inserted in the diagram.
Any further hints?
Yours,
Alex
Re: Multiple links in mindmap example [message #50512 is a reply to message #50401] Tue, 19 September 2006 01:47 Go to previous messageGo to next message
>> "Link Mapping - Single Connector for all Figures"
>> It will help.
I examined two solutions, namely (1) changing
MapCanonicalEditPolicy.refreshConnections as suggested in
http://dev.eclipse.org/newslists/news.eclipse.modeling.gmf/m sg00476.html
and (2) adding MapCanonicalEditPolicy.shouldHandleNotificationEvent
https://bugs.eclipse.org/bugs/show_bug.cgi?id=148021.
Both approches a partial solution to the problem: Only one link is
inserted, but its label is missing.
Comment #9 from Alex Shatalin in the bugzilla entry
https://bugs.eclipse.org/bugs/show_bug.cgi?id=148021 mentions that there
is a modified zip for the mindmap tutorial:
> Answer to #8:
> After small investigation, we have updated projects stored under
> http://www.eclipse.org/gmf/tutorial/mindmap_tutorial_2.zip. From now generated
> code works correctly without any changes with the models from the tutorial. You
> can re-load mindmap_tutorial_2.zip – links should not be duplicated anymore.
> Thank you for reporting this problem and do not hesitate to reiterate this
> thread if you found any additional errors.
I re-load mindmap_tutorial_2.zip (and mindmap_tutorial_3.zip) but the
fix does not work, the mindmap tutorial still produced dublicate links
(without an lables).
-- Alex
Re: Multiple links in mindmap example [message #50622 is a reply to message #50512] Tue, 19 September 2006 05:26 Go to previous messageGo to next message
Hello Alex,
I've just installed mindmap example from http://www.eclipse.org/gmf/tutorial/mindmap_tutorial_2.zip
into my 1.0 installation - includes link works correctly. Please, check that
you've updated mindmap sample. The problem you’ve reported was fixed in mindmap
sample and current .zip file should contain corrected sources.
Alex Shatalin
Re: Multiple links in mindmap example [message #51527 is a reply to message #50622] Tue, 19 September 2006 18:21 Go to previous messageGo to next message
--------------020701040209040703060500
Content-Type: text/plain; charset=UTF-8; format=flowed
Hello Alex,
> http://www.eclipse.org/gmf/tutorial/mindmap_tutorial_2.zip into my 1.0
> installation - includes link works correctly. Please, check that you've
Ok, I tried again to reproduce the problem.
I installed the current version of the mindmap example from the
specified URL in a fresh Eclipse 3.2 SDK (windows) with the Callisto
version of GMF 1.0 and its prereqs.
(To verify whether I am using the correct version of the file
mindmap_tutorial_2.zip: The size of the file is 641.654 bytes and its
md5 checksum is 3b575f22cd2577563f5d4612c78fe5f7.)
The result:
The "includes" links in the mindmap diagram editor are working fine,
but "extends" links are broken. Adding an "extends" link
inserts two parallel links without labels.
(I attached the model files representing a tiny example with two Topic
nodes with a correct "includes" link and a broken "extends" link.)
BTW, are you working with Mac OS X?
Yours,
Alex
Content-Type: text/xml;
name="default.mindmap_diagram"
Content-Disposition: inline;
filename="default.mindmap_diagram"
<notation:Diagram xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:mindmap="http://www.example.org/mindmap" xmlns:notation="http://www.eclipse.org/gmf/runtime/1.0.0/notation" xmi:id="_xlfxAEgqEduPs5m4Idkdgg" type="Mindmap" name="default.mindmap_diagram" measurementUnit="Pixel">
<children xmi:type="notation:Node" xmi:id="_yhkXsEgqEduPs5m4Idkdgg" type="2001">
<children xmi:type="notation:Node" xmi:id="_yhkXtkgqEduPs5m4Idkdgg" type="5002"/>
<children xmi:type="notation:Node" xmi:id="_yhrFYEgqEduPs5m4Idkdgg" type="7001">
<styles xmi:type="notation:DrawerStyle" xmi:id="_yhrFYUgqEduPs5m4Idkdgg"/>
<styles xmi:type="notation:SortingStyle" xmi:id="_yhrFYkgqEduPs5m4Idkdgg"/>
<styles xmi:type="notation:FilteringStyle" xmi:id="_yhrFY0gqEduPs5m4Idkdgg"/>
</children>
<styles xmi:type="notation:FontStyle" xmi:id="_yhkXsUgqEduPs5m4Idkdgg"/>
<styles xmi:type="notation:DescriptionStyle" xmi:id="_yhkXskgqEduPs5m4Idkdgg"/>
<styles xmi:type="notation:FillStyle" xmi:id="_yhkXs0gqEduPs5m4Idkdgg"/>
<styles xmi:type="notation:LineStyle" xmi:id="_yhkXtEgqEduPs5m4Idkdgg"/>
<element xmi:type="mindmap:Topic" href="default.mindmap#//@map/@rootTopics.0"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_yhkXtUgqEduPs5m4Idkdgg" x="312" y="228"/>
</children>
<children xmi:type="notation:Node" xmi:id="_zkz9YEgqEduPs5m4Idkdgg" type="2001">
<children xmi:type="notation:Node" xmi:id="_zk6EAEgqEduPs5m4Idkdgg" type="5002"/>
<children xmi:type="notation:Node" xmi:id="_zk6EAUgqEduPs5m4Idkdgg" type="7001">
<styles xmi:type="notation:DrawerStyle" xmi:id="_zk6EAkgqEduPs5m4Idkdgg"/>
<styles xmi:type="notation:SortingStyle" xmi:id="_zk6EA0gqEduPs5m4Idkdgg"/>
<styles xmi:type="notation:FilteringStyle" xmi:id="_zk6EBEgqEduPs5m4Idkdgg"/>
</children>
<styles xmi:type="notation:FontStyle" xmi:id="_zkz9YUgqEduPs5m4Idkdgg"/>
<styles xmi:type="notation:DescriptionStyle" xmi:id="_zkz9YkgqEduPs5m4Idkdgg"/>
<styles xmi:type="notation:FillStyle" xmi:id="_zkz9Y0gqEduPs5m4Idkdgg"/>
<styles xmi:type="notation:LineStyle" xmi:id="_zkz9ZEgqEduPs5m4Idkdgg"/>
<element xmi:type="mindmap:Topic" href="default.mindmap#//@map/@rootTopics.1"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_zkz9ZUgqEduPs5m4Idkdgg" x="72" y="216"/>
</children>
<styles xmi:type="notation:PageStyle" xmi:id="_xlfxAUgqEduPs5m4Idkdgg"/>
<styles xmi:type="notation:GuideStyle" xmi:id="_xlfxAkgqEduPs5m4Idkdgg"/>
<styles xmi:type="notation:DescriptionStyle" xmi:id="_xlfxA0gqEduPs5m4Idkdgg"/>
<element xmi:type="mindmap:Map" href="default.mindmap#//@map"/>
<edges xmi:type="notation:Edge" xmi:id="_1RfhoEgqEduPs5m4Idkdgg" type="4003" source="_zkz9YEgqEduPs5m4Idkdgg" target="_yhkXsEgqEduPs5m4Idkdgg">
<children xmi:type="notation:Node" xmi:id="_1RfhpUgqEduPs5m4Idkdgg" type="6002">
<layoutConstraint xmi:type="notation:Location" xmi:id="_1RfhpkgqEduPs5m4Idkdgg" x="41" y="41"/>
</children>
<styles xmi:type="notation:RoutingStyle" xmi:id="_1RfhoUgqEduPs5m4Idkdgg"/>
<styles xmi:type="notation:FontStyle" xmi:id="_1RfhokgqEduPs5m4Idkdgg"/>
<styles xmi:type="notation:LineStyle" xmi:id="_1Rfho0gqEduPs5m4Idkdgg"/>
<element xmi:type="mindmap:Relationship" href="default.mindmap#//@map/@relations.0"/>
<bendpoints xmi:type="notation:RelativeBendpoints" xmi:id="_1RfhpEgqEduPs5m4Idkdgg" points="[7, -6, -228, -15]$[126, -101, -109, -110]$[232, 6, -3, -3]"/>
<sourceAnchor xmi:type="notation:IdentityAnchor" xmi:id="_1SKQAEgqEduPs5m4Idkdgg" id="(0.30357143,0.15)"/>
<targetAnchor xmi:type="notation:IdentityAnchor" xmi:id="_1SKQAUgqEduPs5m4Idkdgg" id="(0.21052632,0.075)"/>
</edges>
<edges xmi:type="notation:Edge" xmi:id="_2bgdsEgqEduPs5m4Idkdgg" type="4002" source="_yhkXsEgqEduPs5m4Idkdgg" target="_zkz9YEgqEduPs5m4Idkdgg">
<styles xmi:type="notation:RoutingStyle" xmi:id="_2bgdsUgqEduPs5m4Idkdgg"/>
<styles xmi:type="notation:FontStyle" xmi:id="_2bgdskgqEduPs5m4Idkdgg"/>
<styles xmi:type="notation:LineStyle" xmi:id="_2bgds0gqEduPs5m4Idkdgg"/>
<element xmi:type="mindmap:Relationship" href="default.mindmap#//@map/@relations.1"/>
<bendpoints xmi:type="notation:RelativeBendpoints" xmi:id="_2bgdtEgqEduPs5m4Idkdgg" points="[-28, -3, 205, 21]$[-228, -32, 5, -8]"/>
<targetAnchor xmi:type="notation:IdentityAnchor" xmi:id="_2b44MEgqEduPs5m4Idkdgg" id="(0.625,0.2)"/>
</edges>
</notation:Diagram>
name="default.mindmap"
filename="default.mindmap"
<mindmap:map xmlns:mindmap="http://www.example.org/mindmap">
<rootTopics name="TopicA"/>
<rootTopics name="TopicB"/>
<relations label="includes" source="#//@map/@rootTopics.1" target="#//@map/@rootTopics.0" type="INCLUDES"/>
<relations source="#//@map/@rootTopics.0" target="#//@map/@rootTopics.1"/>
</mindmap:map>
--------------020701040209040703060500--
Re: Multiple links in mindmap example [message #51811 is a reply to message #51527] Wed, 20 September 2006 06:39 Go to previous messageGo to next message
Hello Alex,
I can reproduce this problem with current version of mindmap example (unpacked
from that .zip file) the problem is: code was not re-generated correctly.
To get rid of this problem try open mindmap.gmfgen file and re-generate the
code from it. As a result I can correctly create extends, includes, depends
links. Thank you for reporting this problem – we will correct mindmap.zip
contents asap.
No, I’m working on PC, but we have Mac users in our team. ;-)
Alex Shatalin
Re: Multiple links in mindmap example [message #51832 is a reply to message #51527] Wed, 20 September 2006 06:45 Go to previous message
Hi Alex,
It seems there is a problem with the tutorial step 2 solution zip files, so
if you can use the final solution files, or get the latest from the 1.0.1
maintenance branch from CVS, it should work correctly. I'll be updating the
tutorial soon for the 2.0 stream, and will likely remove these intermediate
solution files.
Rich
On 9/20/06 12:21 AM, in article eepqg6$39d$1@utils.eclipse.org, "Alex
Schwartz" <alexander@schwartzonline.de> wrote:
> Hello Alex,
>> updated mindmap sample. The problem you¹ve reported was fixed in mindmap
> The result:
> Yours,
> Alex
> type="2001">
> type="5002"/>
> type="7001">
> </children>
> </children>
> type="2001">
> type="5002"/>
> type="7001">
> </children>
> </children>
> type="6002">
> </children>
> </edges>
> -8]"/>
> </edges>
> </notation:Diagram>
> </mindmap:map>
Previous Topic:GMF roadmap question
Next Topic:Adding one more column in the property veiw
Current Time: Fri Oct 17 16:42:08 EDT 2025
Powered by FUDForum. Page generated in 0.28663 seconds
