Re: GraphicalRootEditPartWithOverview and Dock classes missing [message #49250 is a reply to message #49144] |
Thu, 12 December 2002 18:10 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: hudsonr.us.eye-bee-em.com
The Overview and Thumbnail figures can no longer exist in the same
lightweight system as the figure which is being shown.
Instead, the Overview should be on its own SWT Control that perhaps sits on
top of your GraphicalEditor's Control. If we have time, we will write a
Composite that does this.
Also, you should be using FreeformGraphicalRootEditPart in most cases, and
your contents EditPart should also use a FreeformLayer as its figure. This
allows scrolling to extend into the negative X and Y regions. I believe your
current Editor prevents the user from moving objects and bendpoints into the
negative regions.
"Gaetan Nadon" <nadon@ca.ibm.com> wrote in message
news:ataivq$mfk$1@rogue.oti.com...
> These are missing from the seeding version of GEF.
> Is this unfinished business or intentional?
> These are used for the Overview box.
> Gaetan Nadon/Toronto/IBM
FUDForum. Page generated in 0.04510 seconds
