Home » Archived » EPF » Lack of Process Overview
Lack of Process Overview [message #48985] |
Fri, 04 April 2008 12:19 |
Originally posted by: padraig.oleary.lero.ie
Hey,
I am using EPF to produce a process framework for product derivation
activities in Software Product Lines.
My main problem is the lack of process overview when using EPF. It's a
shame that EPF is unable to generate a graph of all artefacts and tasks.
As a work around I have used Visio to manually draw process overview
diagrams.
Have other people encountered this problem? Are there any plans in the
future for an overview feature in EPF?
Padraig
Re: Lack of Process Overview [message #49039 is a reply to message #49009] |
Tue, 08 April 2008 12:58 |
Originally posted by: joerg.leuser.daimler.com
I am using EPF to document structured processes (which means there are
many Phases, Iterations and Activities in a hierarchy). The result is that
at the lowest level only a couple of tasks compose the parent
phase/iteration/activity and therefore the graphs for the parents are
quite small (in the sense of context).
danny wrote:
> My users/readers complain that they 'loose context' when they click down
> into a graph.
Yes, I also get such responses.
>> diagrams.
From my experience, the users want to have the question answered 'What is
the complete process' when you introduce a new process to them. When they
got the overview, they are mainly interested in their parts of the process
(for which EPF works quite well). With the graphs generated by/with EPF,
you can't present an overview easily because you don't have graphs that
show multiple hierarchy-levels of your process. Therefore you either
remove the hierarchical modelling from your process or you generate the
overview graphs manually to get overview graphs.
I would appreciate if it would be possible to generate such process
overview graphs within EPF because generating them manually and keeping
them up to date is a lot of work and error-prone.
However, it would be nice if it was still possible to hide some
tasks/artifacts from such overview graphs so only the important ones are
visible.
Jörg
Jörg Leuser
Group Research and Advanced Engineering, Ulm
Daimler AG
Re: Lack of Process Overview [message #49337 is a reply to message #49039] |
Mon, 14 April 2008 20:34 |
danny foncke Messages: 92 Registered: July 2009 |
Member |
I think lots of people would like a more powerful publication approach
I do like what the APF offers, and never woud I want to down-play the
work that got into it
But maybe a separate plugin, from the ground up (or somewhere near the
ground), is what is called for ?
Is the user-base of EPF big enough to justify that kind of project ?
Jörg Leuser wrote:
> that at the lowest level only a couple of tasks compose the parent
>> down into a graph.
>>> a shame that EPF is unable to generate a graph of all artefacts and
>>> tasks. As a work around I have used Visio to manually draw process
>>> overview diagrams.
>>> the future for an overview feature in EPF?
> is the complete process' when you introduce a new process to them. When
> they got the overview, they are mainly interested in their parts of the
> process (for which EPF works quite well). With the graphs generated
> by/with EPF, you can't present an overview easily because you don't have
> graphs that show multiple hierarchy-levels of your process. Therefore
> you either remove the hierarchical modelling from your process or you
> generate the overview graphs manually to get overview graphs.
> them up to date is a lot of work and error-prone. However, it would be
> nice if it was still possible to hide some tasks/artifacts from such
> overview graphs so only the important ones are visible.
> Jörg
> Jörg Leuser
> Daimler AG
Re: Lack of Process Overview [message #518127 is a reply to message #48985] |
Wed, 03 March 2010 08:00 |
Gerhard Schneider Messages: 17 Registered: October 2009 |
Junior Member |
There are two aspects to consider:
(1) The inner structure of your process description. This must fulfill several (partially contradicting) requirements of your users and authors, and this may lead to major restructuring work to optimize the presentation of the process.
(2) The ability of the EPF Composer to create meta-information about a library, for instance, how many items of type X exist and where they are. When working with larger libraries, this would be an enormous help for a library manager. However, does anyone here has an information, if such a feature is on the roadmap?
Gerhard
innoreq® Gerhard Schneider - Prozesse einfach verbessern.
http://www.innoreq.com
Re: Lack of Process Overview [message #588744 is a reply to message #49009] |
> into a graph.
>> diagrams.
visible.
Jörg
Jörg Leuser
Daimler AG
Re: Lack of Process Overview [message #588821 is a reply to message #49039] |
Member |
Jörg Leuser wrote:
>> down into a graph.
>>> overview diagrams.
> Jörg
> Jörg Leuser
> Daimler AG
Re: Lack of Process Overview [message #599241 is a reply to message #48985] |
Junior Member |
Gerhard
Gerhard
Current Time: Fri Jan 03 08:48:13 GMT 2025
Powered by FUDForum. Page generated in 0.04613 seconds
