Help!!!A problem that blocks me to use Eclipse,I am a freshman in using Eclipse!!! [message #48965] |
Tue, 27 May 2003 07:18 |
Originally posted by: mzhenjun.yahoo.com.cn
I had installed JB8 at D:\JBuilder8;
I also installed jdk1.41 at D:\j2sdk141;
I downloaded the zip file of Eclipse2.1:eclipse-examples-2.1-win32.zip adn
extrackd to d:\eclipse;
But when double click the eclipse.exe at at folder d:\eclipse, an
InfomtionBox tell me that Problems during startup
and to check the ".log" file.
the errors are as follows,what should I do?Thank you very much!
!SESSION ------------------------------------------------------------ -------
!ENTRY org.eclipse.core.launcher 4 0
Re: Help!!!A problem that blocks me to use Eclipse,I am a freshman in using Eclipse!!! [message #49113 is a reply to message #48965] |
Tue, 27 May 2003 08:30 |
Originally posted by: d44004.centrum.cz
I am not sure but maybe you should download the eclipse-SDK-2.1-win32.zip
and install the Eclipse from this archive. This should work. Then proceed
to examples, I think it is sufficient to copy only the \"plugins\"
directory from the \"examples\" package to the installed eclipse directory.
good luck
mh
Wintersweet wrote:
> I had installed JB8 at D:\\JBuilder8;
> I also installed jdk1.41 at D:\\j2sdk141;
> extrackd to d:\\eclipse;
> But when double click the eclipse.exe at at folder d:\\eclipse, an
> and to check the \".log\" file.
> !ENTRY org.eclipse.core.launcher 4 0 ÎåÔÂ 26, 2003 14:51:45.31
> !MESSAGE Exception launching the Eclipse Platform:
> !STACK
> java.lang.ExceptionInInitializerError
> at
> org.eclipse.core.internal.plugins.RegistryLoader.processMani festFile(Registr
> yLoader.java:89)
> at
> org.eclipse.core.internal.plugins.RegistryLoader.processPlug inPathFile(Regis
> tryLoader.java:136)
> at
> org.eclipse.core.internal.plugins.RegistryLoader.processPlug inPathEntry(Regi
> stryLoader.java:127)
> at
> org.eclipse.core.internal.plugins.RegistryLoader.processMani festFiles(Regist
> ryLoader.java:104)
> at
> org.eclipse.core.internal.plugins.RegistryLoader.parseRegist ry(RegistryLoade
> r.java:63)
> at
> r.java:71)
> at
> org.eclipse.core.internal.runtime.InternalPlatform.parsePlug ins(InternalPlat
> form.java:779)
> at
> org.eclipse.core.internal.runtime.InternalPlatform.loadRegis try(InternalPlat
> form.java:723)
> at
> org.eclipse.core.internal.runtime.InternalPlatform.loaderSta rtup(InternalPla
> tform.java:574)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
> ..java:25)
> at java.lang.reflect.Method.invoke(Method.java:324)
> at
> org.eclipse.core.internal.boot.InternalBootLoader.startup(In ternalBootLoader
> ..java:1011)
> at
> org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.jav
> a:838)
> at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
> at
> at
> ..java:25)
> at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
> at org.eclipse.core.launcher.Main.run(Main.java:747)
> at org.eclipse.core.launcher.Main.main(Main.java:583)
> Caused by: java.lang.ClassCastException
> at org.apache.xerces.parsers.SAXParser.<init>(SAXParser.java:95)
> at
> org.eclipse.core.internal.plugins.PluginParser.initializePar ser(PluginParser
> ..java:80)
> at
> org.eclipse.core.internal.plugins.PluginParser.<clinit>(PluginParser.java:44
> ... 23 more
FUDForum. Page generated in 0.04235 seconds
