Agent Controller Error [message #48897] |
Tue, 03 January 2006 14:55 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: skibler.kimoce.com
--------------010404060300000100040609
Hi all,
Happy New Year :)
I recently followed the instructions described in the Eclipse tutorial
"Get Started Profiling Applications in Eclipse"
http://www.eclipsezone.com/eclipse/forums/t52038.html
I want to launch profilling view in eclipse but i cann't launch the
agent controller.
Description :
OS : Microsoft Windows Xp Professionnel Version 2002 Sercice pack 2
Eclipse : Eclipse SDK Version 3.1.1 Build id : M20050929-0840
I have set environnement variable system :
PATH : C:\Logiciels\EclipseTptp\raserver\bin
and RASERVER_HOME : C:\Logiciels\EclipseTptp\raserver
I have start SetConfig.bat and it looks good (see attach file :
serviceconfig.xml).
I run the Raserver.exe in a windows service "Agent Controller" but when
i start it a log is generated (see attach file : servicelog.log).
I don't now why the "Agent Controller" doesn't start.
Can you help me please.
Kind regards,
Stephane KIBLER
name="servicelog.log"
Content-Disposition: inline;
filename="servicelog.log"
<CommonBaseEvent creationTime="2006-01-03T14:37:19.918000Z" globalInstanceId="A35101C5760844629C6E81F02421F5DA" msg="Service starting" severity="10" version="1.0.1">
<sourceComponentId component="Data Collection Engine" componentIdType="Application" location="192.168.0.72" locationType="IPV4" processId="3028" subComponent="..\RAServerConfig\RAServerConfigBinding2.cpp" componentType="Eclipse_TPTP"/>
<situation categoryName="ReportSituation">
<situationType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:type="ReportSituation" reasoningScope="INTERNAL" reportCategory="LOG"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.934000Z" globalInstanceId="AE29553F7B8F4C4D97D6D3F31B665B73" msg="Start processing plugin: org.apache.jakarta_commons_logging_1.0.3" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.934000Z" globalInstanceId="AB08A3BC63F64AF58F33C9F7A44E4CC8" msg="Plugin loader: Config file for plugin: org.apache.jakarta_commons_logging_1.0.3 not found" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.934000Z" globalInstanceId="A9598869D70A4F1D8F8D435F23E49C55" msg="Finished processing plugin: org.apache.jakarta_commons_logging_1.0.3" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.934000Z" globalInstanceId="A8105394FBA24603889C424CD4C23CFD" msg="Start processing plugin: org.eclipse.hyades.execution_4.1.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.934000Z" globalInstanceId="A2E72A05F93747FCBF5F624FB4A126A9" msg="Plugin loader: Config file for plugin: org.eclipse.hyades.execution_4.1.0 loaded successfully" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.934000Z" globalInstanceId="A02B914ADD7F43479B365B1D05F4008C" msg="Finished processing plugin: org.eclipse.hyades.execution_4.1.0" severity="10" version="1.0.1">
<sourceComponentId component="Data Collection Engine" componentIdType="Application" location="192.168.0.72" locationType="IPV4" processId="3028" subComponent="...\RAServerConfig\RAServerConfigBinding2.cpp " componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.934000Z" globalInstanceId="A0BDF6FB69C84D01A78B0EDE1E6108FA" msg="Start processing plugin: org.eclipse.hyades.logging.adapter_4.1.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.934000Z" globalInstanceId="A971F013647346AEB3E6303ADF10FF86" msg="Plugin loader: Config file for plugin: org.eclipse.hyades.logging.adapter_4.1.0 loaded successfully" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.934000Z" globalInstanceId="A9C32341894E458481BE398D2DB4A13C" msg="Finished processing plugin: org.eclipse.hyades.logging.adapter_4.1.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.934000Z" globalInstanceId="AB6276746A33441DA2AA2F0E36439620" msg="Start processing plugin: org.eclipse.hyades.logging.core_4.1.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.934000Z" globalInstanceId="A12B3B4368154C18866C1BF94FF7D5DF" msg="This plugin is dependent on org.eclipse.hyades.execution" severity="10" version="1.0.1">
<sourceComponentId component="Data Collection Engine" componentIdType="Application" location="192.168.0.72" locationType="IPV4" processId="3028" subComponent="..\RAServerConfig\RAServerConfigHandler2.cpp" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.934000Z" globalInstanceId="AF983B3785C149949AD9F58CAC43B7C0" msg="Plugin loader: Plugin: org.eclipse.hyades.execution not found" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.934000Z" globalInstanceId="AF8921F74F5A443FB91AAAC89D519BA9" msg="Recovery: since there is no version requirement, trying to load plugin instead: org.eclipse.hyades.execution_4.1.0" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.934000Z" globalInstanceId="A3B3C7C7CC404A72966CA7C47AC02F7D" msg="Plugin org.eclipse.hyades.execution_4.1.0 already loaded" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.934000Z" globalInstanceId="A6CDE07262FD4D4C9BFA153AAC9700A8" msg="Plugin loader: Config file for plugin: org.eclipse.hyades.logging.core_4.1.0 loaded successfully" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.934000Z" globalInstanceId="A581C6B803E946D78646316E6EA8DEA6" msg="Finished processing plugin: org.eclipse.hyades.logging.core_4.1.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.934000Z" globalInstanceId="A299CC71D3AB44F290DA5BE9D8EAD538" msg="Start processing plugin: org.eclipse.hyades.logging.parsers_4.1.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.934000Z" globalInstanceId="A0D486E88153466DBD870038D5A12B81" msg="This plugin is dependent on org.eclipse.hyades.logging.core" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.934000Z" globalInstanceId="A875D2336B1B4E808DE57C2489BA6A31" msg="Plugin loader: Plugin: org.eclipse.hyades.logging.core not found" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.934000Z" globalInstanceId="A874DD9CCDE44B82B44192070442DA3F" msg="Recovery: since there is no version requirement, trying to load plugin instead: org.eclipse.hyades.logging.core_4.1.0" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.934000Z" globalInstanceId="A854924C0AB04BA281BCD9278CD2D887" msg="Plugin org.eclipse.hyades.logging.core_4.1.0 already loaded" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.934000Z" globalInstanceId="A70D12DB0BEF445B9ED3C0529975DC94" msg="This plugin is dependent on org.eclipse.hyades.logging.adapter" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.934000Z" globalInstanceId="AE8C3F56F452467F84154DEE6ADC6A3D" msg="Plugin loader: Plugin: org.eclipse.hyades.logging.adapter not found" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="A4D43074F539405BB38BB261FB3AE130" msg="Recovery: since there is no version requirement, trying to load plugin instead: org.eclipse.hyades.logging.adapter_4.1.0" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="A8D8E6E1EA8044A3A9C564629F754ABE" msg="Plugin org.eclipse.hyades.logging.adapter_4.1.0 already loaded" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="A9EB4572B36244F6B3CF537DBA12B298" msg="Plugin loader: Config file for plugin: org.eclipse.hyades.logging.parsers_4.1.0 loaded successfully" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="A8292E326774473EA0138B78FA71352D" msg="Finished processing plugin: org.eclipse.hyades.logging.parsers_4.1.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="ACF93A872CD048349B6C620DF0E13E62" msg="Start processing plugin: org.eclipse.hyades.perfmon.agents_4.0.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="A0430B087981408A9496F37EFF4FAB0A" msg="This plugin is dependent on org.eclipse.tptp.platform.collection.framework" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="A5DF94E477DC4B6EA7B57A7CE31039E2" msg="Plugin loader: Plugin: org.eclipse.tptp.platform.collection.framework not found" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="A035EA9F273B481ABF78EC5D53BF0808" msg="Recovery: since there is no version requirement, trying to load plugin instead: org.eclipse.tptp.platform.collection.framework_4.1.0" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="AC84FC9DA2F948E6BF920DD739CF8A02" msg="This plugin is dependent on org.eclipse.hyades.execution" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="AD151885040B4323AC824EA063C34BCF" msg="Plugin loader: Plugin: org.eclipse.hyades.execution not found" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="A1F8EFB9055844B4AE685BC00DAA9106" msg="Recovery: since there is no version requirement, trying to load plugin instead: org.eclipse.hyades.execution_4.1.0" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="A7FD883E690D48A090A87FB3123BC8FC" msg="Plugin org.eclipse.hyades.execution_4.1.0 already loaded" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="A1E15E4DCD9A4C98A58AC996843D3F63" msg="This plugin is dependent on org.eclipse.hyades.logging.core" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="AA1AA3BBF33646508C5D96E7D38EF988" msg="Plugin loader: Plugin: org.eclipse.hyades.logging.core not found" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="AFFFA956AAF94E94ACD7B031CD3ECD56" msg="Recovery: since there is no version requirement, trying to load plugin instead: org.eclipse.hyades.logging.core_4.1.0" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="AD5312523CA946B3AD2A8CF3831B7736" msg="Plugin org.eclipse.hyades.logging.core_4.1.0 already loaded" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="A8684B4E223B4D3B94FBB9FAC258915F" msg="Plugin loader: Config file for plugin: org.eclipse.tptp.platform.collection.framework_4.1.0 loaded successfully" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="AF68CD6A94F84AE19AFE594611344606" msg="Recovery: succeeded" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="ADD5D63605DF489E857DB291D80BB223" msg="Plugin loader: Config file for plugin: org.eclipse.hyades.perfmon.agents_4.0.0 loaded successfully" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="A7EE00DDE93E44559E2A6C6147087618" msg="Finished processing plugin: org.eclipse.hyades.perfmon.agents_4.0.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="A0E3ADA79CFF4DBD88EDD0BEC321298B" msg="Start processing plugin: org.eclipse.hyades.test.core_4.1.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="ABD561318E22411D86740A4F9CBA6C03" msg="This plugin is dependent on org.eclipse.hyades.execution" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="AE32CEFA77404BBD9EBD2D2E3DB48769" msg="Plugin loader: Plugin: org.eclipse.hyades.execution not found" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="A2E2AE2A0D774B9D9507D9421A63BB50" msg="Recovery: since there is no version requirement, trying to load plugin instead: org.eclipse.hyades.execution_4.1.0" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="A0419195A57D4DF2BE7133C0F7B823A7" msg="Plugin org.eclipse.hyades.execution_4.1.0 already loaded" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="AB58695E2AB84870A4910BF993A95C8C" msg="This plugin is dependent on org.eclipse.hyades.logging.core" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="AB273962A6C94695A0F63D2F81319FA6" msg="Plugin loader: Plugin: org.eclipse.hyades.logging.core not found" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="A395EB0FA12A459FB286FD4B943FF588" msg="Recovery: since there is no version requirement, trying to load plugin instead: org.eclipse.hyades.logging.core_4.1.0" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="A617903259CC4B7D84CE51ED46968A01" msg="Plugin org.eclipse.hyades.logging.core_4.1.0 already loaded" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="A2984454450C4901B4351605DE11E8E7" msg="Plugin loader: Config file for plugin: org.eclipse.hyades.test.core_4.1.0 loaded successfully" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="A71B3CF9F994467284D307525DAF31C6" msg="Finished processing plugin: org.eclipse.hyades.test.core_4.1.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="A767856A6DA44748AEC22AD7771C4D19" msg="Start processing plugin: org.eclipse.hyades.test.tools.core_4.1.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="A0BB42D17A464235ACA9EA89EEA5062C" msg="This plugin is dependent on org.eclipse.hyades.test.core" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="AE69B65D941344D1A7A85EDEB9125ED4" msg="Plugin loader: Plugin: org.eclipse.hyades.test.core not found" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="A207E7D8F3224EFA8D97F0913D1ADFA7" msg="Recovery: since there is no version requirement, trying to load plugin instead: org.eclipse.hyades.test.core_4.1.0" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="A7310216416B451EAB70CE999AE7DDA2" msg="Plugin org.eclipse.hyades.test.core_4.1.0 already loaded" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="ACE8C5E3C5CA44EA92910EFD7CDC27E6" msg="Plugin loader: Config file for plugin: org.eclipse.hyades.test.tools.core_4.1.0 loaded successfully" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="A81579F9523C4E698EB95A26A431DAEE" msg="Finished processing plugin: org.eclipse.hyades.test.tools.core_4.1.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="A2F486149EA94A3687A91F6A4C8A70A5" msg="Start processing plugin: org.eclipse.tptp.platform.collection.framework_4.1.0" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2006-01-03T14:37:19.950000Z" globalInstanceId="A31802D3EC52430D98D8C8FBF42A8542" msg="Plugin org.eclipse.tptp.platform.collection.framework_4.1.0 already loaded" severity="10" version="1.0.1">
Re: Agent Controller Error [message #48937 is a reply to message #48897] |
Tue, 03 January 2006 16:28 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Samson Wai![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=samwai%40ca.ibm.com) Messages: 46 Registered: July 2009 |
Member |
Hi Stephane,
Can you do the following?
1. cd to "C:\Logiciels\EclipseTptp\raserver\config".
2. Delete "servicelog.log".
3. Edit "serviceconfig.xml" and change the loggingLevel attribute from
"INFORMATION" to "DEBUG". Save the file.
4. cd to "C:\Logiciels\EclipseTptp\raserver\bin".
5. Run "RAServer.exe". Capture any console stdout/err.
6. Attach the new "servicelog.log".
Samson
"KIBLER Stephane" <skibler@kimoce.com> wrote in message
news:dpe3eg$ivi$1@utils.eclipse.org...
> Hi all,
> Happy New Year :)
> agent controller.
> Description :
> serviceconfig.xml).
> Kind regards,
> Stephane KIBLER
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
processId="3028"
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
version="1.0.1">
> </situation>
> </CommonBaseEvent>
Re: Agent Controller Error [message #49057 is a reply to message #48937] |
Tue, 03 January 2006 18:00 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
--------------050504090803000804070905
Hi Samson,
I have do what you want.
I give you my eclipse log and raserver log.
In the eclipse profiling view when i test the connection with raserver
in the eclipse preference it's ok but when i will launch my application
it's ko. Why ?
Thanks for all.
Best regards.
St
FUDForum. Page generated in 0.04322 seconds
