"libxerces-c.so.24: file too short" under Debian !? [message #48768] |
Mon, 02 January 2006 15:06 |
Originally posted by: nospam.home.de
I get this error, when trying to start RAServer:
menge@ls10pc13:/opt/TPTP/bin$ RAStart.sh
Starting Agent Controller
RAServer: error while loading shared libraries: ../lib/libxerces-c.so.24:
file too short
RAServer failed to start
Im a first-timer in both TPTP and profiling in general.
My System:
Debian Etch (testing),
sun-java 1.4.2-10
I also tried the "CarModel"-Tutorial but when starting the profiling, it
dies with: "Error occurred during initialization of VM". I guess this is
because RAServer isn't running, right!?
(Using Eclipse 3.1.1 with TPTP 4.1)
I have followed all the (fairly complicated) instructions to install and
configure RAServer and TPTP. Only the requirement to have
"libstdc++-libc6.2-2.so.3" in my LD_LIBRARY_PATH isn't fulfilled, since i
cant find that in my debian-repsoitories.
Any help would greatly be appreiciated.
Thanks in advance, Sebastian.
Re: "libxerces-c.so.24: file too short" under Debian !? [message #56015 is a reply to message #48861] |
Thu, 02 March 2006 09:42 |
Andreas Heinecke Messages: 21 Registered: July 2009 |
Junior Member |
on my notebook which is running on debian, I've got the same problem. My
other computer which is running on Fedora Core 4 haven't got this
problem. Everything works fine there. the library
libstdc++-libc6.2-2.so.3 is there it is located in
/usr/lib/libstdc++-libc6.2-2.so.3 but i doesn't work.
Can you help me?
Andreas
Samson Wai schrieb:
> Hi Sebastian,
> The library "libstdc++-libc6.2-2.so.3" is a requirement for the Apache
> Xerces-C library "libxerces-c.so" shipped under the Agent Controller's "lib"
> directory.
> bash-2.05$ ldd -r libxerces-c.so
> libpthread.so.0 => /lib/i686/libpthread.so.0 (0x4045d000)
> libstdc++-libc6.2-2.so.3 => /usr/lib/libstdc++-libc6.2-2.so.3
> (0x4048e000)
> libm.so.6 => /lib/i686/libm.so.6 (0x404d2000)
> libc.so.6 => /lib/i686/libc.so.6 (0x404f5000)
> /lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x80000000)
> bash-2.05$
> We build the Xerces-C library using this level of C++ library to make sure
> the Agent Controller can support older Linux kernel 2.4. Newer Linunx kernel
> should have a compatibility RPM package which includes older C++ runtime
> libraries.
> The Debian site has the library available for download:
> http://packages.debian.org/stable/libs/libstdc++2.10-glibc2. 2
> Installing the package will resolve the problem.
> Samson
> "Sebastian Menge" <nospam@home.de> wrote in message
> news:pan.2006.01.02.15.06.15.482382@home.de...
>> Hi
>> file too short
>> My System:
>> sun-java 1.4.2-10
FUDForum. Page generated in 0.03479 seconds
