Home » Language IDEs » PHP Development Tools (PDT) » Xdebug with M3!!!
Re: Xdebug with M3!!! [message #48736 is a reply to message #48680] |
Sat, 01 September 2007 08:05 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
D Kelsey![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=dkel50%40hotmail.com) Messages: 232 Registered: July 2009 |
Hi Ali, you are correct, run doesn't work when you select XDebug as the
debugger. The workaround currently is to switch the launch to the zend
debugger (or create a separate launch). I hope to get a fix into CVS soon.
Dave Kelsey
Ali B. wrote:
> Hurray!!!! :)
> Xdebug plugin is finally integrated into PDT starting M3 now. I know a
> number of you would know by now, but in case some of you out there
> haven't downloaded M3, do it now!! :) As it integrates *beautifully*
> within PDT.
> I'd like to take the chance to Thank Dave Kelsey, and the other plugin
> contributers very much for the enormous amount of effort that was put
> into this plugin. And also for the great, instant, constant and patient
> support Dave has done to it. Thanks again man!
> The truth is I haven't tested it fully yet (the implementation on M3 i
> mean). But my first question is already here: Should the "Run" not work
> when using a script debug using xdebug. I mean when we used to install
> the plugin manually, the option of debugging with xdebug was not present
> in the run dialog. Is it the same reason why we can use it to run?
> should we use the zend debugger for running?
> Cheers,
> Ali
Re: Xdebug with M3!!! [message #48796 is a reply to message #48736] |
Sat, 01 September 2007 18:31 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Ali B.![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=dmondark%40gmail.com) Messages: 66 Registered: July 2009 |
Member |
Having the XDebug enabled in myphp.ini for a long time now, I seem to
have forgotten how to enable the zend debugger back.
I would assume that it is possible to have both debuggers enabled in the
same php.ini, am I correct? if so, could anyone tell me how to enable
the zend debugger back to work side by side with xdebug?
Ali
> Dave Kelsey
> Ali B. wrote:
>> Hurray!!!! :)
>> within PDT.
>> patient support Dave has done to it. Thanks again man!
>> work when using a script debug using xdebug. I mean when we used to
>> install the plugin manually, the option of debugging with xdebug was
>> not present in the run dialog. Is it the same reason why we can use it
>> to run? should we use the zend debugger for running?
>> Cheers,
>> Ali
Re: Xdebug with M3!!! [message #49828 is a reply to message #48796] |
Sun, 09 September 2007 18:09 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: joshbenner.gmail.com
According to Xdebug documentation, it cannot run alongside the Zend
Debugger.
http://www.xdebug.org/docs/install
> Thanks
> Ali
>> soon.
>> Dave Kelsey
>> Ali B. wrote:
>>> Hurray!!!! :)
>>> a number of you would know by now, but in case some of you out there
>>> within PDT.
>>> plugin contributers very much for the enormous amount of effort that
>>> was put into this plugin. And also for the great, instant, constant
>>> and patient support Dave has done to it. Thanks again man!
>>> i mean). But my first question is already here: Should the "Run" not
>>> it to run? should we use the zend debugger for running?
>>> Cheers,
>>> Ali
Re: Xdebug with M3!!! [message #50575 is a reply to message #48736] |
Wed, 12 September 2007 01:38 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Member |
I have just downloaded RC1 and xdebug works on run now as well. Thank
you Dave.
Ali
> Dave Kelsey
> Ali B. wrote:
>> Hurray!!!! :)
>> within PDT.
>> Cheers,
>> Ali
Current Time: Sat Jul 27 12:31:12 GMT 2024
Powered by FUDForum. Page generated in 0.06959 seconds
