Port reset after restart eclipse [message #48657] |
Tue, 07 July 2009 15:57 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: smathys.hotmilk.ch
My private svn server listen to another port than 22 for ssh. When I
change the port in the tab "SSH Settings" from 22 to 2222 it works. But
when I restart eclipse port 22 is again filled in.
Then, the error message looks like this:
Get repository folder children operation failed.
svn: Cannot connect to 'svn+ssh://myServer': There was a problem while
connecting to myServer:22
Steps to reproduce:
- Right click a Repository Location in view SVN Repositories
- Location Properties...
- Tab SSH Settings
- Change Port to 2222, ok.
- eclipse is connected to the repo
- restart eclipse
- the port is reset to 22
This is the scenario for:
eclipse 3.5
svnKit 1.3.0-beta (r5741)
subversion 1.6.2
Is there an other way to change the port in eclipse svn?
thanks
stephan
Re: Port reset after restart eclipse [message #48693 is a reply to message #48657] |
Tue, 07 July 2009 16:09 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Forgot to say that I use mac osx.
On 7.7.2009 17:57 Uhr, stephan mathys wrote:
> Hi
> Steps to reproduce:
> - Tab SSH Settings
> - restart eclipse
> eclipse 3.5
> subversion 1.6.2
> thanks
> stephan
Re: Port reset after restart eclipse [message #49011 is a reply to message #48880] |
Thu, 09 July 2009 12:05 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hello Igor,
thanks for posting my comment!
stephan
On 8.7.2009 16:40 Uhr, Igor Burilo wrote:
> Hello Stephan,
> There's already a relative bug in tracker:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=249074, so I added you
> comments there. Thanks a lot.
> (Note that you can add yourself to CC to track bug activity.)
>>> Hi
>>> Steps to reproduce:
>>> - Tab SSH Settings
>>> - restart eclipse
>>> eclipse 3.5
>>> subversion 1.6.2
>>> thanks
>>> stephan
FUDForum. Page generated in 0.02814 seconds
