Home » Eclipse Projects » Subversive » Port reset after restart eclipse
Port reset after restart eclipse [message #48657] Tue, 07 July 2009 15:57 Go to next message
Originally posted by: smathys.hotmilk.ch
My private svn server listen to another port than 22 for ssh. When I
change the port in the tab "SSH Settings" from 22 to 2222 it works. But
when I restart eclipse port 22 is again filled in.
Then, the error message looks like this:
Get repository folder children operation failed.
svn: Cannot connect to 'svn+ssh://myServer': There was a problem while
connecting to myServer:22
Steps to reproduce:
- Right click a Repository Location in view SVN Repositories
- Location Properties...
- Tab SSH Settings
- Change Port to 2222, ok.
- eclipse is connected to the repo
- restart eclipse
- the port is reset to 22
This is the scenario for:
eclipse 3.5
svnKit 1.3.0-beta (r5741)
subversion 1.6.2
Is there an other way to change the port in eclipse svn?
thanks
stephan
Re: Port reset after restart eclipse [message #48693 is a reply to message #48657] Tue, 07 July 2009 16:09 Go to previous messageGo to next message
Forgot to say that I use mac osx.
On 7.7.2009 17:57 Uhr, stephan mathys wrote:
> Hi
> Steps to reproduce:
> - Tab SSH Settings
> - restart eclipse
> eclipse 3.5
> subversion 1.6.2
> thanks
> stephan
Re: Port reset after restart eclipse [message #48880 is a reply to message #48693] Wed, 08 July 2009 14:40 Go to previous messageGo to next message
Igor Burilo is currently offline Igor BuriloFriend
Hello Stephan,
There's already a relative bug in tracker:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=249074, so I added you
comments there. Thanks a lot.
(Note that you can add yourself to CC to track bug activity.)
>> Hi
>> Steps to reproduce:
>> - Tab SSH Settings
>> - restart eclipse
>> eclipse 3.5
>> subversion 1.6.2
>> thanks
>> stephan
Re: Port reset after restart eclipse [message #49011 is a reply to message #48880] Thu, 09 July 2009 12:05 Go to previous messageGo to next message
Hello Igor,
thanks for posting my comment!
stephan
On 8.7.2009 16:40 Uhr, Igor Burilo wrote:
> Hello Stephan,
>>> Hi
>>> Steps to reproduce:
>>> - Tab SSH Settings
>>> - restart eclipse
>>> eclipse 3.5
>>> subversion 1.6.2
>>> thanks
>>> stephan
Re: Port reset after restart eclipse [message #741948 is a reply to message #49011] Thu, 20 October 2011 03:25 Go to previous message
Minh Viet is currently offline Minh VietFriend
I do with your direction but it's not work. You can help me
Previous Topic:Strange problem with repository UUIDs
Next Topic:Status cache not updating on Commit.
Current Time: Fri Jan 03 08:38:24 GMT 2025
Powered by FUDForum. Page generated in 0.03781 seconds
