Home » Eclipse Projects » Mylyn » Generic Web Connector documentation
Generic Web Connector documentation [message #48627] |
Fri, 16 May 2008 20:25 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: ray.camdenfamily.com
I'm trying to write some code to connect Mylyn to my bug tracker
(lighthousepro.riaforge.org). The docs talk about how to construct your
urls, but say nothing about what my app should return. So for example, I
figured out it wants XML back, but I can't figure out -what- type of XML
it wants.
Where in the docs can I find the exected return values for getting tasks,
getting a task, etc?
Re: Generic Web Connector documentation [message #48714 is a reply to message #48684] |
Fri, 16 May 2008 21:39 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Odd, when I do preview, it complains about invalid XML. So I still don't
get it.
If I make a new query, and point it to url so and so, what should that url
return? Any HTML it wants?
Re: Generic Web Connector documentation [message #48982 is a reply to message #48773] |
Thu, 22 May 2008 14:13 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Ahh ok thank you! So you DO need to format your code (and yes, I have
control over the results) and you need to tell Eclipse how to parse the
code.
This is what I'm talking about - it isn't documented very well I think.
Re: Generic Web Connector documentation [message #589583 is a reply to message #48684] |
Fri, 16 May 2008 21:39 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
get it.
Re: Generic Web Connector documentation [message #589682 is a reply to message #48773] |
Thu, 22 May 2008 14:13 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
code.
Current Time: Wed Jul 17 14:50:38 GMT 2024
Powered by FUDForum. Page generated in 0.04557 seconds
