Home » Archived » DSDP - Real-Time Software Components (RTSC) » RTSC with Eclipse CDT
RTSC with Eclipse CDT [message #398] Thu, 20 November 2008 06:45 Go to next message
I just started to evaluate RTSC and I'd like to a have a closer look, if
it's appropriate for our needs. My first question is: can I use CDT for
developing with RTSC or do I have to use CCStudio? I tried to set up CDT
Ganymede and Europe with the XDC plugins, but couldn't find the support in
the IDE.
thanks,
Clemens
Re: RTSC with Eclipse CDT [message #403 is a reply to message #398] Fri, 21 November 2008 01:44 Go to previous messageGo to next message
Clemens Fuchs wrote:
> in the IDE.
> thanks,
> Clemens
You can use CDT. The easiest way to do this is to simply setup CDT's
"make command" (in a non-managed make project) to be the xdc command
included in the XDCtools. The xdc command is a simple shell that
invokes GNU make 3.81 and, as a result, it supports all of the normal
GNU make command line options. In particular, you can pass goals on the
command line to finely control what is built.
This level of integration is not as complete as that provided by
CCStudio, but I find it sufficient for most purposes.
Re: RTSC with Eclipse CDT [message #407 is a reply to message #403] Fri, 21 November 2008 05:29 Go to previous messageGo to next message
thanks, now my CDT is set up correctly.
Are there plans to improve CDT support? Especially for editing xs, xdc and
cfg files?
Re: RTSC with Eclipse CDT [message #412 is a reply to message #407] Sun, 23 November 2008 17:38 Go to previous messageGo to next message
> and cfg files?
Absolutely. We currently working out the bugs in a graphical editor for
..cfg files that allows you to compose these scripts easily (no need to
write JavaScript) _and_ review the result of running the script.
As for .xs and .xdc files we don't have any development underway. But
it's easy to see the sort of capabilities that should be available:
syntax highlighting, method auto-completion, and links to method
documentation.
Since .xs files are JavaScript, syntax highlighting is easy (there are a
variety of JavaScript aware editors) but some work is necessary to
integrate method completion and summary documentation.
Finally, although .xdc files have no pre-existing editors that
understand their contents, they are somewhat easier than arbitrary
JavaScript files: the IDL is purely declarative, strongly typed, and
it's relatively easy to determine what each identifiers refers to.
The challenge for both .xs and .xdc files is in finding appropriate
editors to start with.
Re: In AGR While Creating Datapool, "Link to Datapool" is not visible [message #1788265] Wed, 30 May 2018 12:30 Go to previous message
Previous Topic:Using sibling modules
Next Topic:RTSC targets tree started in RTSC source repository
Current Time: Sat Oct 18 04:01:45 EDT 2025
Powered by FUDForum. Page generated in 0.04326 seconds
