Home » Archived » M2M (model-to-model transformation) » [ATL] non deterministic behaivor
[ATL] non deterministic behaivor [message #47586] |
Tue, 19 June 2007 14:39 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: hein..fokus.fraunhofer
--------------040301050401000801050405
Hi all,
I've finished my first ATL transformation from a UML UseCase model to a
UML HighLevel model that contains additionally classes derived from
usecases. However, I'm getting a non deterministic behavior.
After several executions of the same transformation I'm getting a
different output model each time. More precisely the difference occurs
in the nestedClassifier association of the created Class from the
UseCase that includes other usecases ("buy a ticket" includes "pay a
ticket" and "deliver a ticket", the created Class "buy a ticket" should
nested the Classes "deliver a ticket" and "pay a ticket", but sometimes
the transformation provides such a model and sometimes it provides me
only one nested Class or non nested Classes.
The corresponding ATL rule is here, additionally I've attached the
source uml model and the whole atl transformation file.
rule UseCase{
from u1:UML2!UseCase
to u2:UML2!UseCase(
name<-u1.name,
--owner<-u1.owner,
include<-u1.include
usecaseclass1:UML2!Class (
name<-u1.name,
useCase<-u1,
nestedClassifier<- if u1.include->size()>0 then
UML2!Class.allInstances()->select(c |
u1.include->collect(i|i.addition.name)->includes(c.name) )
else Set{} endif
Thanks in advance for any help
Christian
name="UseCases2HighLevel.atl"
Content-Disposition: inline;
filename="UseCases2HighLevel.atl"
module UseCases2HighLevel; -- Module Template
create OUT : UML2 refining IN : UML2;
rule Model{
from m1:UML2!Model
to m2:UML2!Model(
name<-m1.name,
packagedElement<-m1.packagedElement
-- create new Class Package
--p1:UML2!Package(
--name<-'ClassPackage'
-- add all Classes to this Package
--packagedElement<-UML2!Class.allInstances()->union(UML2!Association.allInstances())
--nestingPackage<-m2
do {
--m2.packagedElement<- m1.packagedElement->asSet()->append(Set{thisModule.createPackage(m1)});
thisModule.createPackage(m2);
rule createPackage(np:UML2!Package){
to c : UML2!Package
do{
--set attributes here
c.name<-'ClassPackage';
c.nestingPackage<-np;
c.packagedElement<-UML2!Class.allInstances()->union(UML2!Association.allInstances());
np.packagedElement<-Set{c};
rule Package{
from p1:UML2!Package(p1.oclIsTypeOf(UML2!Package) and (not (p1.oclIsTypeOf(UML2!Model))))
to p2:UML2!Package(
name<-p1.name,
packagedElement<-p1.packagedElement
rule Asscociation{
from a1:UML2!Association
to a2:UML2!Association(
name<-a1.name,
memberEnd<-a1.memberEnd,
ownedEnd<-a1.ownedEnd
a3:UML2!Association(
name<-a1.name+'source_target'
--ownedEnd<-a1.ownedEnd
--ownedEnd <- thisModule.resolveTemp(a1.ownedEnd, 'c1')
do { -- this do part is new
if (a1.ownedEnd->size()>0) {
a3.ownedEnd<-Set{
thisModule.resolveTemp(a1.ownedEnd->asSequence()->first(),'p3'),
thisModule.resolveTemp(a1.ownedEnd->asSequence()->last(),'p3')
--a1.ownedEnd->asSequence()->first().toString().println();
-- a3.ownedEnd <- thisModule.resolveTemp(a1.memberEnd->asSequence()->first(), 'p2');
--a3.ownedEnd <- thisModule.resolveTemp(
-- Class!Class->allInstances()->
-- select(c | c.name =
Re: [ATL] non deterministic behaivor [message #47624 is a reply to message #47586] |
Tue, 19 June 2007 17:07 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Frédéric Jouault![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=frederic.jouault%40univ-nantes.fr) Messages: 572 Registered: July 2009 |
Could you please simplify your scenario (i.e., mainly the
transformation) to the smallest one exhibiting the problematic behavior?
This step helps a lot, but is best done by somebody knowing all the
details of the scenario ;-).
Thanks.
Frédéric Jouault
Christian Hein wrote:
> Hi all,
> rule UseCase{
> to u2:UML2!UseCase(
> name<-u1.name,
> --owner<-u1.owner,
> include<-u1.include
> name<-u1.name,
> useCase<-u1,
> else Set{} endif
> Cheers,
> Christian
> rule Model{
> from m1:UML2!Model
> to m2:UML2!Model(
> name<-m1.name,
> --p1:UML2!Package(
> do {
> to c : UML2!Package
> do{
> rule Package{
> to p2:UML2!Package(
> name<-p1.name,
> rule Asscociation{
> name<-a1.name,
> a3.ownedEnd<-Set{
> -- �NameOfTheClassCorrespondingToTheSearchedTable�)
> -- , 'c1');
> } else {
> a1.ownedEnd->size().toString().println();
> -- a3.ownedEnd <- thisModule.resolveTemp(a1.ownedEnd, 'c1');
> -- a3.memberEnd <- thisModule.resolveTemp(a1.memberEnd, 'c1');
> rule Property{
> from p1:UML2!Property
> to p2:UML2!Property(
> name<-p1.name,
> type<-p1.type,
> upperValue<-p1.upperValue,
> lowerValue<-p1.lowerValue
> p3:UML2!Property(
> name<-p1.name,
> do {
> if (p1.type.oclIsTypeOf(UML2!Actor)) {
> thisModule.resolveTemp(p1.type,'actorclass1').toString().pri ntln();
> p3.type<-thisModule.resolveTemp(p1.type,'actorclass1');
> } else {
> thisModule.resolveTemp(p1.type,'usecaseclass1').toString().p rintln();
> p3.type<-thisModule.resolveTemp(p1.type,'usecaseclass1');
> rule LiteralInteger{
> from l1:UML2!LiteralInteger
> to l2:UML2!LiteralInteger(
> value<-l1.value
> rule LiteralUnlimitedNatural{
> from l1:UML2!LiteralUnlimitedNatural
> to l2:UML2!LiteralUnlimitedNatural(
> value<-l1.value
> rule Include{
> from i1:UML2!Include
> to i2:UML2!Include(
> name<-i1.name,
> addition<-i1.addition
> a1:UML2!Association(name<-i1.name)
> rule Actor{
> from actor1:UML2!Actor
> to actor2:UML2!Actor(
> name<-actor1.name,
> general<-actor1.general
> actorclass1:UML2!Class(
> name<-actor1.name,
> general<-if actor1.general->size()>0 then
> UML2!Class.allInstances()->select(x|x.name=actor1.general->first().name)
> else Set{} endif
> rule UseCase{
> to u2:UML2!UseCase(
> name<-u1.name,
> --owner<-u1.owner,
> include<-u1.include
> name<-u1.name,
> useCase<-u1,
> UML2!Class.allInstances()->select(c | u1.include->collect(i|i.addition.name)->includes(c.name) )
> else Set{} endif
> <?xml version="1.0" encoding="ASCII"?>
> <uml:Model xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:uml="http://www.eclipse.org/uml2/2.0.0/UML" xmi:id="{20257490-18CA-4f87-BDE6-E69D03C0F923}" name="Model">
> <packagedElement xsi:type="uml:Package" xmi:id="{016E3AA9-FCB6-4bae-B227-63619281A08D}" name="UseCase">
> <packagedElement xsi:type="uml:Association" xmi:id="{1B6D6218-CC14-4549-B114-DC3194C3FF19}" name="Association7">
> <ownedEnd xmi:id="P:{BE09C181-4341-4a05-8C02-3F84EBFD23AC}" name="source" type="{BE09C181-4341-4a05-8C02-3F84EBFD23AC}">
> <upperValue xsi:type="uml:LiteralUnlimitedNatural" xmi:id="_-cXS4BsqEdyXSNchEVw7Pg" value="1"/>
> <lowerValue xsi:type="uml:LiteralInteger" xmi:id="_-chD4BsqEdyXSNchEVw7Pg" value="1"/>
> </ownedEnd>
> <ownedEnd xmi:id="P:{4782FF3E-D09F-4c23-877D-621FE620B46F}" name="target" type="{4782FF3E-D09F-4c23-877D-621FE620B46F}">
> <upperValue xsi:type="uml:LiteralUnlimitedNatural" xmi:id="_-chD4RsqEdyXSNchEVw7Pg" value="1"/>
> <lowerValue xsi:type="uml:LiteralInteger" xmi:id="_-chD4hsqEdyXSNchEVw7Pg" value="1"/>
> </ownedEnd>
> </packagedElement>
> <packagedElement xsi:type="uml:Association" xmi:id="{25CDA0B9-127F-4a45-BD22-3251C864249D}" name="Association8">
> <upperValue xsi:type="uml:LiteralUnlimitedNatural" xmi:id="_-chD4xsqEdyXSNchEVw7Pg" value="1"/>
> <lowerValue xsi:type="uml:LiteralInteger" xmi:id="_-chD5BsqEdyXSNchEVw7Pg" value="1"/>
> </ownedEnd>
> <ownedEnd xmi:id="P:{A48DE74E-1C20-458b-A846-58894235F891}" name="target" type="{A48DE74E-1C20-458b-A846-58894235F891}">
> <upperValue xsi:type="uml:LiteralUnlimitedNatural" xmi:id="_-chD5RsqEdyXSNchEVw7Pg" value="1"/>
> <lowerValue xsi:type="uml:LiteralInteger" xmi:id="_-cqN0BsqEdyXSNchEVw7Pg" value="1"/>
> </ownedEnd>
> </packagedElement>
> <packagedElement xsi:type="uml:Association" xmi:id="{3902B3C5-DE64-4e74-9A98-6D70838E12E4}" name="Association9">
> <upperValue xsi:type="uml:LiteralUnlimitedNatural" xmi:id="_-cqN0RsqEdyXSNchEVw7Pg" value="1"/>
> <lowerValue xsi:type="uml:LiteralInteger" xmi:id="_-cqN0hsqEdyXSNchEVw7Pg" value="1"/>
> </ownedEnd>
> <ownedEnd xmi:id="P:{540A7F91-9B4D-417c-9469-DA6F8F53D403}" name="target" type="{540A7F91-9B4D-417c-9469-DA6F8F53D403}">
> <upperValue xsi:type="uml:LiteralUnlimitedNatural" xmi:id="_-cqN0xsqEdyXSNchEVw7Pg" value="1"/>
> <lowerValue xsi:type="uml:LiteralInteger" xmi:id="_-cqN1BsqEdyXSNchEVw7Pg" value="1"/>
> </ownedEnd>
> </packagedElement>
> <packagedElement xsi:type="uml:Actor" xmi:id="{BE09C181-4341-4a05-8C02-3F84EBFD23AC}" name="customer">
> <generalization xmi:id="{2E8AFA2C-E5DE-4b2f-87E0-CDF3C13B156A}" general="{7D9D3859-C7AE-4b82-94F8-5E59DB099142}"/>
> </packagedElement>
> <packagedElement xsi:type="uml:Association" xmi:id="{AE34985C-E288-42a6-8341-696E0E89068A}" name="Association6">
> <ownedEnd xmi:id="P:{BD832C10-D31F-4592-B1A1-88B272F506CD}" name="source" type="{BD832C10-D31F-4592-B1A1-88B272F506CD}">
> <upperValue xsi:type="uml:LiteralUnlimitedNatural" xmi:id="_-dG5wBsqEdyXSNchEVw7Pg" value="1"/>
> <lowerValue xsi:type="uml:LiteralInteger" xmi:id="_-dG5wRsqEdyXSNchEVw7Pg" value="1"/>
> </ownedEnd>
> <ownedEnd xmi:id="P:{D8E69A5B-8CC7-4714-8EB7-1DF40F084F29}" name="target" type="{D8E69A5B-8CC7-4714-8EB7-1DF40F084F29}">
> <upperValue xsi:type="uml:LiteralUnlimitedNatural" xmi:id="_-dG5whsqEdyXSNchEVw7Pg" value="1"/>
> <lowerValue xsi:type="uml:LiteralInteger" xmi:id="_-dG5wxsqEdyXSNchEVw7Pg" value="1"/>
> </ownedEnd>
> </packagedElement>
> <packagedElement xsi:type="uml:Actor" xmi:id="{BD832C10-D31F-4592-B1A1-88B272F506CD}" name="stuff">
> <generalization xmi:id="{16661073-770E-4ef8-A307-72593B9B52C5}" general="{7D9D3859-C7AE-4b82-94F8-5E59DB099142}"/>
> </packagedElement>
> <packagedElement xsi:type="uml:Association" xmi:id="{F52C8A06-7AFF-4ec2-88C6-FABA56004392}" name="Association3">
> <ownedEnd xmi:id="P:{7D9D3859-C7AE-4b82-94F8-5E59DB099142}" name="source" type="{7D9D3859-C7AE-4b82-94F8-5E59DB099142}">
> <upperValue xsi:type="uml:LiteralUnlimitedNatural" xmi:id="_-dG5xBsqEdyXSNchEVw7Pg" value="1"/>
> <lowerValue xsi:type="uml:LiteralInteger" xmi:id="_-dG5xRsqEdyXSNchEVw7Pg" value="1"/>
> </ownedEnd>
> <ownedEnd xmi:id="P:{9A000CE4-A4C9-44c6-8186-9AF822866031}" name="target" type="{9A000CE4-A4C9-44c6-8186-9AF822866031}">
> <upperValue xsi:type="uml:LiteralUnlimitedNatural" xmi:id="_-dG5xhsqEdyXSNchEVw7Pg" value="1"/>
> <lowerValue xsi:type="uml:LiteralInteger" xmi:id="_-dG5xxsqEdyXSNchEVw7Pg" value="1"/>
> </ownedEnd>
> </packagedElement>
> <packagedElement xsi:type="uml:Association" xmi:id="{F8C97987-D7E3-4da6-B5CA-046D034E4C69}" name="Association5">
> <upperValue xsi:type="uml:LiteralUnlimitedNatural" xmi:id="_-dG5yBsqEdyXSNchEVw7Pg" value="1"/>
> <lowerValue xsi:type="uml:LiteralInteger" xmi:id="_-dG5yRsqEdyXSNchEVw7Pg" value="1"/>
> </ownedEnd>
> <ownedEnd xmi:id="P:{610E9F75-AF6F-4d99-8D2B-9BE82C67BAFD}" name="target" type="{610E9F75-AF6F-4d99-8D2B-9BE82C67BAFD}">
> <upperValue xsi:type="uml:LiteralUnlimitedNatural" xmi:id="_-dG5yhsqEdyXSNchEVw7Pg" value="1"/>
> <lowerValue xsi:type="uml:LiteralInteger" xmi:id="_-dG5yxsqEdyXSNchEVw7Pg" value="1"/>
> </ownedEnd>
> </packagedElement>
> <packagedElement xsi:type="uml:Actor" xmi:id="{7D9D3859-C7AE-4b82-94F8-5E59DB099142}" name="User"/>
> <packagedElement xsi:type="uml:UseCase" xmi:id="{A48DE74E-1C20-458b-A846-58894235F891}" name="buy a ticket">
> <include xmi:id="{3B12F9D5-DF6D-4a39-8F5E-7DD577D548B1}" name="Include10" addition="{540A7F91-9B4D-417c-9469-DA6F8F53D403}"/>
> <include xmi:id="{15E681E8-754D-4faf-8E7D-0DCCF5DE8B69}" name="Include11" addition="{D8E69A5B-8CC7-4714-8EB7-1DF40F084F29}"/>
> </packagedElement>
> <packagedElement xsi:type="uml:UseCase" xmi:id="{D8E69A5B-8CC7-4714-8EB7-1DF40F084F29}" name="deliver a ticket"/>
> <packagedElement xsi:type="uml:UseCase" xmi:id="{9A000CE4-A4C9-44c6-8186-9AF822866031}" name="log in"/>
> <packagedElement xsi:type="uml:UseCase" xmi:id="{610E9F75-AF6F-4d99-8D2B-9BE82C67BAFD}" name="log out"/>
> <packagedElement xsi:type="uml:UseCase" xmi:id="{540A7F91-9B4D-417c-9469-DA6F8F53D403}" name="pay a ticket"/>
> <packagedElement xsi:type="uml:UseCase" xmi:id="{4782FF3E-D09F-4c23-877D-621FE620B46F}" name="reserve a ticket"/>
> </packagedElement>
> </uml:Model>
Re: [ATL] non deterministic behaivor [message #47739 is a reply to message #47586] |
Wed, 20 June 2007 06:13 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Dennis Wagelaar![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=dennis.wagelaar%40vub.ac.be) Messages: 147 Registered: July 2009 |
Christian Hein schreef:
> Hi all,
> rule UseCase{
> to u2:UML2!UseCase(
> name<-u1.name,
> --owner<-u1.owner,
> include<-u1.include
> name<-u1.name,
> useCase<-u1,
> else Set{} endif
> Cheers,
> Christian
Hi Christian,
It looks like you're trying to navigate the target model using
UML2!Class.allInstances(). Since target elements are often created in
random order, you cannot rely on them. You should use resolveTemp() to
assign non-default mappings, such as the mapping from u1 to
usecaseclass1. The rule would look like this:
rule UseCase{
to u2:UML2!UseCase(
name<-u1.name,
--owner<-u1.owner,
include<-u1.include
name<-u1.name,
useCase<-u1,
nestedClassifier<- u1.include
->collect(i|thisModule
->resolveTemp(i.addition, 'usecaseclass1')
This will give you the classes to which the included use case are
mapped. Note that you again cannot navigate from the class you resolved,
since it may not have been initialised.
Dennis
Re: [ATL] non deterministic behaivor [message #47922 is a reply to message #47739] |
Thu, 21 June 2007 10:53 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Thank you Dennis for discovering the issue.
I would not say that you cannot navigate the target model *because*
target elements are often created in random order.
Instead, I would say that navigating the target model is prohibited by
ATL semantics. Therefore, the ATL engine can create elements in whatever
order makes more sense for it.
I know this may seem like a detail, but I believe it is important to
note that this is a design decision, which brings interesting
properties, not a bug ;-).
Frédéric Jouault
>> Hi all,
>> a UML HighLevel model that contains additionally classes derived from
>> should nested the Classes "deliver a ticket" and "pay a ticket", but
>> sometimes the transformation provides such a model and sometimes it
>> provides me only one nested Class or non nested Classes.
>> rule UseCase{
>> to u2:UML2!UseCase(
>> name<-u1.name,
>> --owner<-u1.owner,
>> include<-u1.include
>> name<-u1.name,
>> useCase<-u1,
>> else Set{} endif
>> Cheers,
>> Christian
> Hi Christian,
> rule UseCase{
> to u2:UML2!UseCase(
> name<-u1.name,
> --owner<-u1.owner,
> include<-u1.include
> name<-u1.name,
> useCase<-u1,
> Dennis
Re: [ATL] non deterministic behaivor [message #48072 is a reply to message #47922] |
Thu, 21 June 2007 13:51 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Frédéric Jouault schreef:
> Hello,
That leaves one open issue: UML2!Class.allInstances() should *not*
return any elements from a target model...
Dennis
> Best regards,
> Frédéric Jouault
>>> Hi all,
>>> occurs in the nestedClassifier association of the created Class from
>>> the UseCase that includes other usecases ("buy a ticket" includes
>>> "pay a ticket" and "deliver a ticket", the created Class "buy a
>>> ticket" should nested the Classes "deliver a ticket" and "pay a
>>> ticket", but sometimes the transformation provides such a model and
>>> sometimes it provides me only one nested Class or non nested Classes.
>>> rule UseCase{
>>> to u2:UML2!UseCase(
>>> name<-u1.name,
>>> --owner<-u1.owner,
>>> include<-u1.include
>>> name<-u1.name,
>>> useCase<-u1,
>>> else Set{} endif
>>> Cheers,
>>> Christian
>> Hi Christian,
>> rule UseCase{
>> to u2:UML2!UseCase(
>> name<-u1.name,
>> --owner<-u1.owner,
>> include<-u1.include
>> name<-u1.name,
>> useCase<-u1,
>> resolved, since it may not have been initialised.
>> Regards,
>> Dennis
Re: [ATL] non deterministic behaivor [message #48102 is a reply to message #48072] |
Thu, 21 June 2007 15:31 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
resolveTemp() to
>> whatever order makes more sense for it.
I totally agree with that.
AFAIK there is no open bug on this issue (yet?), but this is a planned
improvement. You can see this in the list of VM parameters, in which
there is "allowTargetNavigation" commented out (until it is implemented,
of course) ;-):
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2m/org .eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.adt.debug/src/o rg/eclipse/m2m/atl/adt/launching/AtlLauncherTools.java?revis ion=1.6&root=Modeling_Project&view=markup
The reasons why this option needs to be implemented rather than simply
disabling target model navigation are:
- firstly, that some already written transformations may depend on
target model navigation, and we do not want to completely break them,
- secondly, that the ATL VM can be used with other languages than ATL,
which may not all have this restriction on target model navigation.
Frédéric Jouault
M2M Project Lead
Current Time: Sun Sep 01 02:25:26 GMT 2024
Powered by FUDForum. Page generated in 0.03996 seconds
