Re: code assistant / imports / documentation [message #47540 is a reply to message #47480] |
Tue, 03 June 2003 16:07 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: faust.acm.org
1st issue: Go to Window->preferences->compiler->problems tab. Change "usage
of deprecated API" option.
2nd issue: Organize imports under Source menu is your friend (Ctrl-Shift-O).
Would you like an unorganize imports option? ;)
Randy
"Marcel St
Re: code assistant / imports / documentation [message #48471 is a reply to message #47698] |
Wed, 04 June 2003 09:32 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I see. So you want a refactoring for replacing deprecated methods. And you'd
like obvious candidates to be offered as replacement suggestions or happen
automatically or something along those lines. Enter a bug report with an
enhancement request.
Randy
"Marcel St
Re: code assistant / imports / documentation [message #49447 is a reply to message #49182] |
Wed, 04 June 2003 23:10 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Agreed, it might be a dubious enhancement. But I can imagine something like
a migration tool which could take advantage of the new refactoring
particpants story to do a refactor rename based on a set of migration rules.
Randy
"Martin M
FUDForum. Page generated in 0.04604 seconds
