| Value validation [message #47445] |
Tue, 08 June 2004 06:59  |
Originally posted by: invalid.soft-gems.net
Ed,
Is there a built-in facility to check whether a given value is valid
compared to the effective facets of its type? I can write this myself, but
I would suspect that this is an often needed feature when working with
schemas, so it would be cool if there is already an implementation.
Mike
www.soft-gems.net
| Re: Value validation [message #47651 is a reply to message #47622] |
Wed, 09 June 2004 04:33  |
Ed,
> XSDFeature.getValue will return the default value of an
XSDElementDeclaration or
> an XSDAttributeDeclaration. This is an XML Schema infoset property. It is
> computed from XSDFeature.getLexicalValue, which is the string literal
default as
> it appears in the schema.
Thank you.
Mike
www.soft-gems.net
| Re: Value validation [message #588272 is a reply to message #47445] |
Tue, 08 June 2004 07:24  |
Mike,
To determine if a literal is valid with respect to a simple type, you can use
either XSDSimpleTypeDefinition.isValidLiteral or
XSDSimpleTypeDefinition.assess.
Mike Lischke wrote:
> Ed,
> Mike
> www.soft-gems.net
| Re: Value validation [message #589115 is a reply to message #47505] |
Tue, 08 June 2004 10:19  |
Works exactly as I wanted it (except for localisation of the error
message, but this is subordinated, currently). Thanks a bunch Ed.
Mike
www.soft-gems.net
| Re: Value validation [message #589128 is a reply to message #47535] |
Tue, 08 June 2004 10:55  |
Mike,
The translation is done at the end of the development cycle. IBM pays for it (and
it's not cheap!) and then donates it to Eclipse. For standalone support, we create
the xsd.resources.jar based on the donation from IBM, so that currently contains
the translation from the 1.1.1.1 release. Unzipping that file and copying the
*.properties file to where the English plugin.properties file is should get you
translation for what was translated before...
> Mike
> www.soft-gems.net
| Re: Value validation [message #589139 is a reply to message #47569] |
Tue, 08 June 2004 10:56  |
Ed Merks wrote:
> Mike,
it (and
create
contains
the
you
This is excellent news Ed. We were thinking of doing this (at least
partially) ourselves but this way is much better :-)
A last question for today: How would I go to get an assigned default value
for an attribute if there is one? I could not find anything related to
"default" in XSDSimpleTypeDefinition interface.
Mike
www.soft-gems.net
| Re: Value validation [message #589147 is a reply to message #47593] |
Tue, 08 June 2004 11:09  |
Mike,
XSDFeature.getValue will return the default value of an XSDElementDeclaration or
computed from XSDFeature.getLexicalValue, which is the string literal default as
Mike Lischke wrote:
> Ed Merks wrote:
> > Mike,
> it (and
> create
> contains
> the
> you
> Mike
> www.soft-gems.net
| Re: Value validation [message #589157 is a reply to message #47622] |
Ed,
default as
Thank you.
Mike
www.soft-gems.net
FUDForum. Page generated in 0.07537 seconds
