Connecting to JIRA through a central authentication service (CAS) [message #47410] |
Tue, 22 April 2008 22:39 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: nclemeur.daesim.com
I am trying to connect to a JIRA instance where the authentication has
been customised and is handled in a separate application (CAS).
The problem I am having is that it seems that mylyn does not handle well
the redirect to the authentication form (from https://www.mysite.com/jira
to https://www.mysite.com/cas). The error displayed is "Server error:
(302)Found"
JIRA is running on tomcat which is accessed through mod_jk and apache. For
authentication, I am using CAS (http://www.ja-sig.org/products/cas/)
through mod_auth_cas which means that the authentification is done before
the JIRA instance is accessed. Once the authentication is done in CAS, the
user is automatically redirected through original request.In JIRA, I have
a filter that check the remote user and automatically log the user in.
I would appreciate any advice helping to found where the problem is.
I am running JIRA 3.12.2 and Mylyn 2.3.
PS: to test that my eclipse configuration was ok I have successfully
connected to http://jira.codehaus.org.
FUDForum. Page generated in 0.03000 seconds
