milestone plan for aspectj integration into eclipse [message #4126] |
Sun, 15 September 2002 15:56 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: markus.nospam.com
i am studying aspectj for about a week now. the idea is fascinating
and the possibilities using aspect oriented-programming seem to be
tremendous.
i have tried the eclipse plugin for aspectj. integrating the aspectj
language inside the IDE seems to be the right approach. i also
appreciate that eclipse itself is providing a plugin instead of
leaving this to the aspectj team.
however i am a bit worried that the depth of integration will be to
shallow if aspectj is not part of the main eclipse project plan.
i am especially concerned about th compiler integration. right now the
aspectj plugin doesn't support incremental builds, the
outline view is not updated automatically etc pp.
so i was wondering if there are plans to integrate aspectj seamlessly
into eclipse and make aspectj a first class citizen in eclipse.
--markus
Re: milestone plan for aspectj integration into eclipse [message #4197 is a reply to message #4126] |
Sun, 15 September 2002 16:50 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: dorodok.inbox.lv
about plans of AJDT you can read at developers' mailing list:
http://dev.eclipse.org/mhonarc/lists/ajdt-dev/maillist.html
concerning incremental compiler integration: it will be available
in aspectj version 1.1
(dig into aspectj users mailing list at aspectj.org)
you will be surprised about adopting of eclipse incremental compiler
by aspectj team
regards
> tremendous.
> --markus
Re: milestone plan for aspectj integration into eclipse [message #561499 is a reply to message #4126] |
by aspectj team
regards
> tremendous.
> --markus
FUDForum. Page generated in 0.03468 seconds
