Problem Loading Ecore Model [message #47404 is a reply to message #47242] |
Mon, 30 June 2008 22:06 |
Originally posted by: uneebtariq.gmail.com
Felix Dorner wrote:
> Mark Melia wrote:
>> Hi all,
>> I wonder if someone can help me. I want to create a DSL defined using an
>> ECore metamodel. This DSL will generate OCL. I have defined the
>> metamodel in ECore, but I am unsure how to generate the OCL now. Will
>> M2T allow for this? When will it be released? Can JET generate non-java
>> text?
> Can generate any text you want.
> Here is how you run a JET transform on an ecore document:
http://help.eclipse.org/help33/topic/org.eclipse.jet.doc/tas ks/usingJetWithEMF.xhtml
> The wiki is also helpful:
> http://wiki.eclipse.org/M2T-JET
Hey Hi
I am working with mark on this project and have neva Used JET before. I
am having a couple of problems using JET.
1. How to load ecore model as an input? What should be the
extension(myecore.?)
2. Plz can someone give me a simple example of loading ecore in JET and
transforming it into code.
waiting for ur response
Uneeb Janjua
FUDForum. Page generated in 0.03945 seconds
