Home » Language IDEs » AspectJ » ajdt_1.2.0M2 content assist does not work
Re: ajdt_1.2.0M2 content assist does not work [message #47237 is a reply to message #47162] |
Tue, 01 February 2005 13:27 |
Originally posted by: mchapman.uk.ibm.com
On Mon, 31 Jan 2005 13:40:00 +0800, Guofeng Zhang wrote:
> When I type code in the aspect, the content assist does not work, but in the
> java editor, it works well.
> Shoud I do specialconfiguration for AJDT.
> Platform: JRE 1.5, Eclipse 3.0.1 AJDT 1.2.0M2
Content assist, via Control-Space, should be working fairly well in
1.2.0M2, without requiring any special configuration. But there are
limitations - you can't complete against pointcut names for example. See
the following bug report for the details of these limitations:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=74419
Maybe you could post an example of what you are trying to perform the
content assist against?
Matt.
Matt Chapman
AJDT Development, http://www.eclipse.org/ajdt
Re: ajdt_1.2.0M2 content assist does not work [message #47346 is a reply to message #47237] |
Wed, 02 February 2005 13:07 |
guofeng zhang Messages: 49 Registered: July 2009 |
Member |
My usage is general, for example, when I type a "dot", I hope there is a
method list dispalyed.
thanks for your reply.
guofeng
"Matt Chapman" <mchapman@uk.ibm.com> wrote in message
news:pan.2005.02.01.13.27.56.698339@uk.ibm.com...
the
> Matt.
> Matt Chapman
Re: ajdt_1.2.0M2 content assist does not work [message #586344 is a reply to message #47162] |
Matt Chapman Messages: 429 Registered: July 2009 |
Matt.
Matt Chapman
Re: ajdt_1.2.0M2 content assist does not work [message #586387 is a reply to message #47237] |
Member |
guofeng
the
> Matt.
> Matt Chapman
Current Time: Sat Oct 19 18:38:07 GMT 2024
Powered by FUDForum. Page generated in 0.03428 seconds
