Suggestions for display of editable and non-editable cells in Grid [message #47160] |
Wed, 23 January 2008 07:02 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: chethan.kumarbr.in.bosch.com
Can anyone give suggestions for my below points,
1.In grid as the default background is white; we can't differentiate
between editable and non-editable cells till we select the cell.
So what would be the better GUI approach to represent editable and
non-editable cells?
2.What is the better GUI approach to display default values in grid
(editable/non-editable)? Default values are values that the user has not
entered but a possible value he could enter in the cell.
Thanks & Regards,
Chethan
Re: Suggestions for display of editable and non-editable cells in Grid [message #49541 is a reply to message #47589] |
Mon, 18 February 2008 07:26 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hello Chris,
Thanks for the answer...
I am already painting the background and setting images,text in columns
using 'GridColumnLabelProvider', which does the same work as cell
renderers i feel.
Is this cell renderer different from 'GridColumnLabelProvider'? If same,
which will be the better one to use in Grid viewer, cell renderers or
Chethan
Re: Suggestions for display of editable and non-editable cells in Grid [message #588628 is a reply to message #47589] |
Hello Chris,
renderers i feel.
Chethan
FUDForum. Page generated in 0.02734 seconds
